NVME SSD Samsung 960 EVO Works!
Just wanted to report that I've recently installed the Samsung 960 EVO 500GB MZ-V6E500 2280. Running Manjaro ARM as primary drive. I wasn't sure it would work since the wiki shows the 970s don't work. I haven't noticed any heat from the drive but then I haven't done any particularly large read/writes. Seems stable thus far. Been using it about a week at this point.
What tests should I run before updating the wiki to note this thing is good to go?
Is there any other information anyone else would like about this?
Is there a standard for testing or verifying drives before we add them to the wiki? Perhaps I missed this somewhere if it already exists. Maybe worth noting at the top of the page or linking to those type of instructions here if/when they exist. https://wiki.pine64.org/index.php/Pinebo...patibility
smartctl 7.1 2019-12-30 r5022 [aarch64-linux-5.5.0-3.1-MANJARO-ARM] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number:                       Samsung SSD 960 EVO 500GB Serial Number:                      S3X4NB0K501841X Firmware Version:                   3B7QCXE7 PCI Vendor/Subsystem ID:            0x144d IEEE OUI Identifier:                0x002538 Total NVM Capacity:                 500,107,862,016 [500 GB] Unallocated NVM Capacity:           0 Controller ID:                      2 Number of Namespaces:               1 Namespace 1 Size/Capacity:          500,107,862,016 [500 GB] Namespace 1 Utilization:            285,444,767,744 [285 GB] Namespace 1 Formatted LBA Size:     512 Namespace 1 IEEE EUI-64:            002538 5581b4b31f Local Time is:                      Mon Feb 24 23:24:31 2020 CST Firmware Updates (0x16):            3 Slots, no Reset required Optional Admin Commands (0x0007):   Security Format Frmw_DL Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Maximum Data Transfer Size:         512 Pages Warning  Comp. Temp. Threshold:     83 Celsius Critical Comp. Temp. Threshold:     85 Celsius Supported Power States St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat 0 +     6.04W       -        -    0  0  0  0        0       0 1 +     5.09W       -        -    1  1  1  1        0       0 2 +     4.08W       -        -    2  2  2  2        0       0 3 -   0.0400W       -        -    3  3  3  3      210    1500 4 -   0.0050W       -        -    4  4  4  4     2200    6000 Supported LBA Sizes (NSID 0x1) Id Fmt  Data  Metadt  Rel_Perf 0 +     512       0         0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning:                   0x00 Temperature:                        34 Celsius Available Spare:                    100% Available Spare Threshold:          10% Percentage Used:                    1% Data Units Read:                    8,699,295 [4.45 TB] Data Units Written:                 9,937,895 [5.08 TB] Host Read Commands:                 86,990,454 Host Write Commands:                60,449,849 Controller Busy Time:               357 Power Cycles:                       195 Power On Hours:                     243 Unsafe Shutdowns:                   44 Media and Data Integrity Errors:    0 Error Information Log Entries:      83 Warning  Comp. Temperature Time:    0 Critical Comp. Temperature Time:    0 Temperature Sensor 1:               34 Celsius Temperature Sensor 2:               39 Celsius Error Information (NVMe Log 0x01, max 64 entries) Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS  0         83     0  0x00b0  0x4212  0x028            0     -     -  1         82     0  0x0016  0x4212  0x028            0     1     -  2         81     0  0x0011  0x4212  0x028            0     1     -  3         80     0  0x000a  0x4212  0x028            0     1     -  4         79     0  0x0056  0x4212  0x028            0     -     -  5         78     0  0x0046  0x4212  0x028            0     -     -  6         77     0  0x007c  0x4212  0x028            0     -     -  7         76     0  0x0078  0x4212  0x028            0     -     -  8         75     0  0x00c6  0x4212  0x028            0     -     -  9         74     0  0x00da  0x4212  0x028            0     -     - 10         73     0  0x0054  0x4212  0x028            0     -     - 11         72     0  0x00fe  0x4212  0x028            0     -     - 12         71     0  0x00c8  0x4212  0x028            0     -     - 13         70     0  0x00f6  0x4212  0x028            0     -     - 14         69     0  0x003f  0x4212  0x028            0     -     - 15         68     0  0x006c  0x4212  0x028            0     -     - ... (48 entries not shown)
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff critical_warning : 0 temperature : 32 C available_spare : 100% available_spare_threshold : 10% percentage_used : 1% endurance group critical warning summary: 0 data_units_read : 8,699,271 data_units_written : 9,937,359 host_read_commands : 86,989,736 host_write_commands : 60,440,491 controller_busy_time : 357 power_cycles : 195 power_on_hours : 243 unsafe_shutdowns : 44 media_errors : 0 num_err_log_entries : 83 Warning Temperature Time : 0 Critical Composite Temperature Time : 0 Temperature Sensor 1           : 32 C Temperature Sensor 2           : 38 C Thermal Management T1 Trans Count : 0 Thermal Management T2 Trans Count : 0 Thermal Management T1 Total Time : 0 Thermal Management T2 Total Time : 0
test: (g=0): rw=randrw, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=64 fio-3.18 Starting 1 process test: (groupid=0, jobs=1): err= 0: pid=4794: Mon Feb 24 23:33:25 2020  read: IOPS=44.3k, BW=173MiB/s (182MB/s)(3070MiB/17736msec)   bw (  KiB/s): min=148798, max=205644, per=100.00%, avg=177361.71, stdev=13880.86, samples=35   iops        : min=37199, max=51411, avg=44340.17, stdev=3470.22, samples=35  write: IOPS=14.8k, BW=57.8MiB/s (60.7MB/s)(1026MiB/17736msec); 0 zone resets   bw (  KiB/s): min=50307, max=68894, per=100.00%, avg=59279.29, stdev=4794.75, samples=35   iops        : min=12576, max=17223, avg=14819.37, stdev=1198.76, samples=35  cpu          : usr=17.72%, sys=52.03%, ctx=273652, majf=0, minf=17  IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%     issued rwts: total=785920,262656,0,0 short=0,0,0,0 dropped=0,0,0,0     latency   : target=0, window=0, percentile=100.00%, depth=64 Run status group 0 (all jobs):   READ: bw=173MiB/s (182MB/s), 173MiB/s-173MiB/s (182MB/s-182MB/s), io=3070MiB (3219MB), run=17736-17736msec  WRITE: bw=57.8MiB/s (60.7MB/s), 57.8MiB/s-57.8MiB/s (60.7MB/s-60.7MB/s), io=1026MiB (1076MB), run=17736-17736msec Disk stats (read/write):  nvme0n1: ios=783951/262028, merge=0/17, ticks=589056/5627, in_queue=190, util=99.89%
.jpg   Samsung 960 Evo MZ-V6E500.jpg (Size: 414.55 KB / Downloads: 1,037)
sweet.
useful info:
drive power reported information
power usage
battery impact
anything not working, like suspend
any configurations you have made
(02-24-2020, 05:18 PM)xmixahlx Wrote: sweet.
useful info:
power usage
battery impact
I'm not a linux noob per say but I've not worked with power or battery stuff within linux much. Only recently started using Linux on my personal laptops. Are there specific commands to run for each of these items?
This feeds in to my secondary questions about building a sort of testing suite(list of items and commands) for this testing so others who might give this a go can just use those and provide this information up front and in a uniform way.
Thanks for clarifying your request with needed commands so I can capture this info and then we can put together a testing doc of sorts.
  NVMe drives not detected mattpenn 18 31,286 12-24-2024, 08:54 PM
  NVMe reukiodo 0 3,019 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,492 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,757 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,423 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 6,390 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,551 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 5,685 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,589 07-09-2021, 08:45 PM
Last Post: moonwalkers
Lightbulb Bluetooth headsets - what works? embhorn 17 38,604 03-22-2021, 11:45 PM
Last Post: ab1jx
