Pinephone
Hallo all,
Sorry to bump in like this, I am struggling to connect my phone to my pc, it is not picking it up, what must I do
My camera is also not working
And it does not pick up my sd card
Any url that might assist with the issues please
regards
We don't know which OS you are using.
I would suggest trying out mobian.
https://wiki.mobian-project.org/doku.php?id=install
Back camera works.
Connection to a PC using an USB cable is more trickier, though.
If you haven't modified your phone, it won't work. See:
https://forum.pine64.org/showthread.php?tid=10255
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Hello,
Back camera works.
Thanks for the reply
I am using UBports
I dont mind if the front camera is not working as yet
I will test my Carrier connection today to see if it is working, if not I will swicth to Mobian then
regards
https://forum.pine64.org/showthread.php?tid=9796
Also check this link. The update channel you are using could make a difference.
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Connection to a PC using an USB cable is more trickier, though.
That's not entirely true. Connection to a Type A port with the supplied cable (or a similar one like the one supplied with the Pixel) will work - it's how you'd typically use jumpdrive to flash to the eMMC. It's host mode, and maybe connection to other USB C ports, that won't work.
You're right. Jumpdrive certainly works.
As it was implied, that it didn't work, I thought it was meant connecting the PP running one distro to a computer using the supplied USB cable, which in my case does not work given I haven't made any hardware modification.
lsbus does not report any new device having been attached when I connect the PP to my laptop running debian. You can imagine what will happen on other non linux based OS. : )
  PinePhone - boot from microSD laserpyramid 9 751 4 hours ago
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 387 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 261 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,274 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,894 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 644 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,468 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 524 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,764 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,053 12-04-2023, 02:14 AM
Last Post: Peter Gamma
