Pinephone
Hallo all,
Sorry to bump in like this, I am struggling to connect my phone to my pc, it is not picking it up, what must I do
My camera is also not working
And it does not pick up my sd card
Any url that might assist with the issues please
regards
We don't know which OS you are using.
I would suggest trying out mobian.
https://wiki.mobian-project.org/doku.php?id=install
Back camera works.
Connection to a PC using an USB cable is more trickier, though.
If you haven't modified your phone, it won't work. See:
https://forum.pine64.org/showthread.php?tid=10255
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Hello,
Back camera works.
Thanks for the reply
I am using UBports
I dont mind if the front camera is not working as yet
I will test my Carrier connection today to see if it is working, if not I will swicth to Mobian then
regards
https://forum.pine64.org/showthread.php?tid=9796
Also check this link. The update channel you are using could make a difference.
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Connection to a PC using an USB cable is more trickier, though.
That's not entirely true. Connection to a Type A port with the supplied cable (or a similar one like the one supplied with the Pixel) will work - it's how you'd typically use jumpdrive to flash to the eMMC. It's host mode, and maybe connection to other USB C ports, that won't work.
You're right. Jumpdrive certainly works.
As it was implied, that it didn't work, I thought it was meant connecting the PP running one distro to a computer using the supplied USB cable, which in my case does not work given I haven't made any hardware modification.
lsbus does not report any new device having been attached when I connect the PP to my laptop running debian. You can imagine what will happen on other non linux based OS. : )
  Pinephone visibly losing power while plugged in Hiraghm 9 8,979 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,669 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,827 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,905 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,645 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,634 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,189 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,829 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,225 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,539 10-21-2025, 12:12 PM
Last Post: Richy_T
