NVME problem
I've installed (as described in wiki) Intel SSD 6 660p Series 1024Gb (SSDPEKNW010T8X1). Booted several times. Everything was fine. But next day after booting pbp there is no NVME disk at all (no disk in fdisk and lsblk output). Maybe I can check smth else to debug this problem if disk is not dead? Thanks in advance!
Did you have to fold the ribbon cable from the main board to the adapter, at all? Pinches on the ribbon cable can cause it to disappear.
(07-01-2020, 08:23 AM)tophneal Wrote: Did you have to fold the ribbon cable from the main board to the adapter, at all? Pinches on the ribbon cable can cause it to disappear.
I was able to do this without folding the ribbon. It looks like ok. Just ordered nvme to usb adapter to check if the ssd is broken.
UPD1:
After I secured the ribbon with tape I was able to get nvme work after boot once. But after next reboot it is not available anymore.
UPD2:
Smth wired. The nvme seems to work only after poweroff but not after reboot.
UPD3:
After adding the following line to crontab issue is probably solved (because save switch is not supported).
sudo nvme set-feature /dev/nvme0 -f 2 -v 2
The battery was lower 15% today for the first time after I've installed the ssd.
  NVMe drives not detected mattpenn 18 31,234 12-24-2024, 08:54 PM
  NVMe reukiodo 0 3,010 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,470 11-17-2024, 04:24 AM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 5,763 09-11-2024, 07:05 AM
Last Post: MikoBob
  Problem with USB 3.0 Type A hobbitus 4 5,894 07-15-2023, 11:14 AM
Last Post: dachalife
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,742 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,409 11-28-2022, 12:56 PM
  NVme intall usage? tkudog 2 6,381 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,539 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 5,669 07-22-2021, 05:57 PM
Last Post: calinb
