Yet another new Pinebook keyboard problem
At least the Enter key does not seem to work, so I can't do the initial setup. I see other messages about dead keyboards but I don't yet see a solution.
This seems to be a huuuge problem.
space?
Some ancient sw used tab & space for menus
OR ctrl j, ctrl m?
Try an external keyboard.
:wq
I solved my keyboard problem.
First, I made a mistake by trying to set up the system using the keyboard. That does not work. I had to plug in a mouse and do all of the setup selections using the mouse.
Then, I selected the keyboard layout as one of the setup questions. I can't remember what I selected, but I think it was something like 103 or 105 key default layout, and that worked. As of then, the enter key started to work. And all of the other keys also worked; I checked them all.
So my PineBook is now good to go.
And I apologize for my previous complaints, but somebody should add to the startup instructions:
1. plug in a mouse
2. select the correct keyboard layout (and specify what it should be).
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,924 10-05-2026, 12:42 PM
  pinephone keyboard oliveira11670 1 2,716 05-20-2026, 09:19 AM
Last Post: zetabeta
  Replacement battery for PineBook Pro DrYak 5 9,638 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,238 03-23-2025, 03:31 PM
Last Post: WEF
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,014 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,083 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 4,049 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 240,328 09-13-2023, 03:43 AM
Last Post: k3dAR
  Problem with USB 3.0 Type A hobbitus 4 5,952 07-15-2023, 11:14 AM
Last Post: dachalife
  Separate ISO keyboard for PBP Besouro 0 3,072 06-04-2023, 02:51 PM
Last Post: Besouro
