Hardware video acceleration in Chromium on Manjaro
Lightbulb
Earlier today, when i was bored, I turned on "Hardware-accelerated video decode" and "GPU rasterization" in Chromium browser ( chrome://flags ). To my surprise, it actually worked well, bringing CPU load to 80% when playing plain H.264, compared to 160% before.
I am currently Manjaro 21.05 with GNOME 40 on my Pinebook Pro.
I wonder if it works "just for me", so you guys might give it a try.
The relative change in performance seems quite good, on the other hand 80% of a single core to play a video does not really sound like fully working acceleration.
Did you check which of these two options caused the improvement? What test or website did you use?
Is it really hardware accelerated?
Open the devtools with F12 and open the `media` tab. (it's in the hamburger menu under "More Tools" if you've never opened it before)
It will tell you if it's hardware accel'd. For me it shows FFmpegVideoDecoder, which is software. I think MojoVideoDecoder would be hardware.
(05-31-2021, 07:14 AM)maxjrh Wrote: Is it really hardware accelerated?
I'm a little embarrassed, but you are right. I am seeing "FFmpegVideoDecoder" as well. Turning HW acceleration off and on running with different test videos and formats actually show no effect in CPU usage.
What I observed with my first test was a mere coincidence and I got all exited over it and posted prematurely ;-)
And also Chromium would happily lie about HW Video acceleration in chrome://gpu
"Boosted" my PBP with a load of Placebo.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,609 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,286 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,394 02-19-2025, 12:49 PM
Last Post: zkajdan
  Inexpected reboot during watching youtube video regivanx 1 3,536 10-19-2024, 06:02 AM
  (xorg) Video driver? falken 2 4,748 07-03-2024, 12:01 PM
Last Post: falken
  Manjaro Sway Theme Broken Eighty8 1 4,139 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,671 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,026 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 3,351 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,290 12-13-2023, 07:22 PM
Last Post: trillobite
