Manjaro Dim Display (Brightness 40%) After Every System Reboot
Hello All,
I have a Pinebook Pro running factory Manjaro. Every single time I reboot the system, the brightness is reset to 40%. I have to use the Fn+F2 key to manually adjust the brightness to 70%.
Does anyone have a solution so that the display brightness will be set at 70% every single time the system is started?
I searched online for hours. I didn't find a solution that works.
Mine was always getting reset to about 1% on every boot. The culprit was systemd-backlight@.service. This saves the brightness on shutdown and restore it on startup. But it was always saving the 0% brightness the screen is set to after closing the lid before shutdown! So I just disabled it.
[Image: b6012d21108bcad487dc265542ab4ab1-full.png]
These tabs (On AC Power/On Batter) set the brightness at startup. Cheers!
edit: Also if you uncheck the top box on both tabs the last brightness value will be set at startup.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,919 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,385 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,946 02-19-2025, 12:49 PM
Last Post: zkajdan
  Inexpected reboot during watching youtube video regivanx 1 2,541 10-19-2024, 06:02 AM
  Manjaro Sway Theme Broken Eighty8 1 3,316 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 3,131 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,735 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,986 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,303 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,581 12-11-2023, 03:47 AM
Last Post: calinb
