Problems to start the PineTab
I sometimes need several attempts to start the PineTab after shutdown. I don't know if it's the "video issue" or something else. Normally it starts after 2s of holding down the power button, but sometimes it needs 10s+ several times. Have you experienced the same behavior?
Edit: Currently Mobian, running internal emmc but had the same experience with UT also...
Yes, sometimes it feels like it got "stuck" in some weird state - not clear if off or just booting, so need to hold power button for long several times. "Tips and tricks" section has a quote by Aperricio from IRC how to do it properly, but I still need to master it Smile
https://wiki.pine64.org/index.php?title=PineTab#Reset
Quote:You have to press power button for 7-8s. It makes a sound and you know it's totally off. 3 seconds after, power button again for 2-3s and it will start to boot.
(09-13-2020, 12:23 PM)Lex-2008 Wrote: Yes, sometimes it feels like it got "stuck" in some weird state - not clear if off or just booting, so need to hold power button for long several times. "Tips and tricks" section has a quote by Aperricio from IRC how to do it properly, but I still need to master it Smile
Ah, good to know that it is not totally uncommon and related to just my device. Thank you for the info!
  Unknown Startup Password for Newly Delivered PINETAB-V - 10.1" 8GB/128GB krupine2 1 407 10-05-2026, 12:44 PM
  Not able to power on PineTab anymore zkajdan 4 6,166 01-12-2025, 10:38 PM
Last Post: vatin
Question Will Pinetab 2 spare parts be available? vatin 6 9,069 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 3,453 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 4,506 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 3,072 09-18-2023, 06:31 AM
Last Post: michaelengel
  Pinetab 2 screen no longer coming on Fibonacci 9 13,754 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 10,725 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 5,020 04-05-2023, 06:58 PM
Last Post: msm
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 13,093 02-10-2022, 08:31 PM
Last Post: barray
