Dark screen on boot up (?) on new Pinebook Pro with Manjaro
Okay, I just have to laugh. I updated the packages on the SD card, rebooted it, and it came up with a dark screen. I can just re-image to the downgraded SD image for the card, and repeat the process, but an SD card image that can actually access the eMMC would be really nice right about now.
More importantly, thuis shows that this pitfall is still in the Manjaro package server, after other people have fallen for it. I am done with Manjaro at this point and will be looking for other OSes, and if they can't fix this, I think the Pinebook community should seriously consider moving to another distro
The Ubuntu Fosse SD image boots the laptop with a working display and lets me access the eMMC.
SO now I just need to know what to put into /etc/ to get the backlight turned on during boot up.
1. Just screen back-light not turning on?
2. Or LED over F2 key doesn't go GREEN from RED?
If case 2, you shold have done two "dd" commands for u-boot configuration after update (before reboot).
(08-18-2020, 04:35 AM)cynist Wrote: 1. Just screen back-light not turning on?
Just the screen backlight.
Boot ubuntu (SD) I assume it works?
edit/ make a file called "bright" (with sudo/su)
#/usr/bin/bash
cd /sys/class/backlight/edp-backlight
echo 3200 > brightness
(for some reason, space before and after ">" seems to be neccesary)
sudo chmod 777 bright
mount emmc (rootfs, not boot)
sudo cp bright to /mnt/emmc/root (replace emmc with appropriate)
shutdown, remove card
boot with emmc, ctr-alt-F2, do it twice (or more), wait until sure is booted
All this is blind, type carefully
login as root,,password ,, ./bright,, alt-F1 (preceding "./" is essential)
I have looked (grep) in /etc, trying to find where backlight values are stored, no luck
There is a systemd unit, seems dead or part of something else
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 8,776 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 1,676 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 8,727 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 2,883 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 3,262 02-19-2025, 12:49 PM
Last Post: zkajdan
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 3,674 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 4,484 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,373 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 7,260 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 2,485 03-08-2024, 08:41 AM
