U-Boot with direct NVMe boot support for eMMC/SPI Flash
#71
(07-07-2020, 08:47 AM)mamboman777 Wrote: Ok.  Still seeking clarification as I'd really like this to work the first time.  1. Download and extract from https://github.com/pcm720/u-boot-build-scripts
2. Run build.sh
3. then run "sudo dd if=spiflash.bin of=/dev/mtd0
If this is already documented someplace, I apologize, but could you please point me in the right direction.
Thanks!
Yup, download that repo as a zip or use git clone, run the build script, navigate into the directory with the finished images, and run the command.
(07-07-2020, 08:42 AM)tophneal Wrote:
(07-07-2020, 08:35 AM)mamboman777 Wrote: Thanks for the encouragement.  Making a backup now.
Just to be clear, you are saying I should follow instructions from this, right?  https://github.com/pcm720/u-boot-build-scripts
No, his earlier, rockchip-based uboot has this command for writing to SPI:
Looking at the build script of the most recent (your link,) that spiflash.bin will be in your build folder.
2. Run build.sh
Thanks!
First of all, to build the U-Boot on x32/x64 PC, you'll need to install aarch64-linux-gnu-gcc cross-compiler.
Then, clone the repository with "git clone --recursive", this will also clone ATF and U-Boot repositories as submodules.
After that, just build the U-Boot with build.sh and write spiflash.bin to /dev/mtd0 via dd.
2. Run build.sh
Thanks!
It's going to be a while, based off of the speed it looks like dejadup is running.  I've also got to make sure I have a working SD manjaro image before I get started.  That being said, I was planning on building and running this on my aarch64 PBP then flashing directly from there.  pcm720, are you saying that I should do something else?
2. Run build.sh
Thanks!
If you're going to build it directly on your PBP, you'll have to remove every occurence of "CROSS_COMPILE=aarch64-linux-gnu-" from build.sh.
That should be enough.
(07-07-2020, 09:12 AM)mamboman777 Wrote: It's going to be a while, based off of the speed it looks like dejadup is running.  I've also got to make sure I have a working SD manjaro image before I get started.  That being said, I was planning on building and running this on my aarch64 PBP then flashing directly from there.  pcm720, are you saying that I should do something else?
pcm may have assumed you would be doing this on an x86 machine, as building uboot on the PBP can take quite a while. You can still do it on you PBP from what I last recall, just keep that in mind. If you have a Linux on your eMMC, you'd be better off building it from that install. An SD will give you poorer performance building this. beat me to it.
Well, I've got a pretty good 4 core 8 thread Xeon sitting here.  Would I be better off using that?  I could even work on that while this backup finishes.
(07-07-2020, 09:21 AM)mamboman777 Wrote: Well, I've got a pretty good 4 core 8 thread Xeon sitting here.  Would I be better off using that?  I could even work on that while this backup finishes.
Probably not a bad idea. It should certainly take a lot less time.
So after I fun build.sh, how do I get the code to the spi on my PBP?
(07-07-2020, 09:47 AM)mamboman777 Wrote: So after I fun build.sh, how do I get the code to the spi on my PBP?
Put it on a USB (if you're using your x86 machine to build it) and use the previous dd command to write it to SPI from the PBP.
Well, I got lots of errors on the build.sh.  I think I may be missing dependencies?
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
make: *** No rule to make target 'realclean'.  Stop.
make: *** No rule to make target 'bl31'.  Stop.
cp: cannot stat 'build/rk3399/release/bl31/bl31.elf': No such file or directory
make: *** No rule to make target 'mrproper'.  Stop.
cp: cannot stat '../build/bl31.elf': No such file or directory
make: *** No rule to make target 'pinebook-pro-rk3399_defconfig'.  Stop.
make: *** No targets specified and no makefile found.  Stop.
/home/joshua/Desktop/u-boot-build-scripts-master/build.sh: line 37: tools/mkimage: No such file or directory
dd: failed to open 'idbloader-spi.img': No such file or directory
cat: u-boot.itb: No such file or directory
cp: cannot stat 'idbloader-spi.img': No such file or directory
cp: cannot stat 'idbloader.img': No such file or directory
cp: cannot stat 'u-boot.itb': No such file or directory
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 750 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 1,024 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 3,105 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 1,260 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 24,810 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 15,659 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,056 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,738 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,845 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,394 09-04-2024, 10:35 AM
