Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
(06-21-2020, 02:34 AM)brzegorz Wrote:
(06-20-2020, 01:37 PM)slow_motion Wrote: Hi everyone,
nice thread Smile
i was wondering if anyone managed to get Chiaki working on pinebook pro manjaro edition?
On the git there are only x86 images.
Otherwise, is there an equivalent software for arm to connect remotely to ps4?
Thank you
If you're compiling from AUR on Manjaro, you can add "aarch64" to list of architectures and there's a huge change it'll just compile, since it's built for Android too.
Thanks for the tip! i'm new to building packages, didn't know we could specify the architecture Smile
But the "official" package threw cpp errors. I ended up downloading the chiaki-git package instead of chiaki, edited PKGBUILD to add aarch64 as you suggested and it works!
Thank you
Eduke32 built nicely on system with Debian Bullseye! I've tried the HRP but end up with lots of missing textures, not exactly sure why yet. Has anyone else tried or had any luck?
Hi all!
I've managed to build and run Xash3D on Manjaro using Docker!
I've used a Debian Arm32 image to compile and run everything; i made a repo on github with a Dockerfile and some scripts (there is also a Readme file)
If someone wants to try it (or fork it and make it better) here it is:
https://github.com/gira93/xash3d-docker-pbp
It's not the final and most stable method but it's a start.
Hi guys, been a long time since I haven't come in here and I was wondering if anyone has tried to run box86, it's an x86 to arm emulator and it seems to give pretty good results with running simple indie games and basic apps like steam on the raspberry, I was gonna try to figure it out but I was thinking maybe someone already has ^^
Here's the link to the GitHub if anyone's interested: https://github.com/ptitSeb/box86
(06-30-2020, 02:32 AM)Idaho Wrote: Hi guys, been a long time since I haven't come in here and I was wondering if anyone has tried to run box86, it's an x86 to arm emulator and it seems to give pretty good results with running simple indie games and basic apps like steam on the raspberry, I was gonna try to figure it out but I was thinking maybe someone already has ^^
The page says that it needs a 32bit host; i don't know if that means it will not work on a 64bit cpu or that it needs 32bit libraries; I should try to compile it under a Docker image (as i did with Xash3d).
Starcraft on Pinebookpro Manjaro
http://45.76.81.249/Pinebook64/pinebook-...starcraft/
// Make sure we have Lua5.1 !!
// When multiple Lua versions are present
// We need to define lua version during cmake
// And stratagus works probably with Lua 5.1 only
// For the build's sake remove lua (5.3) and lua52
// pacman -R lua lua52
// Lets install a few dependencies
// Assuming we already have the
// GCC build environment in place
# pacman -S
cmake
lua51
harfbuzz
tolua++
libtheora
libmikmod
sdl2 sdl2_graphics sdl2_image sdl2_mixer sdl2_net sdl2_ttf
sqlite
libmng
wget
// I have uploaded the working sources to my repo
// for others to replicate the build
// Original location is https://launchpad.net/stratagus/+download
// I have patched the source code so that it builds using GCC 8 and 9
// Create a working directory STARCRAFT
// Download stratagus sources and extract them
mkdir $HOME/STARCRAFT
cd $HOME/STARCRAFT
wget http://45.76.81.249/Pinebook64/pinebook-...hed.tar.gz
gunzip stratagus_2.2.7.patched.tar.gz
tar -xvf stratagus_2.2.7.patched.tar
cd stratagus_2.2.7.patched
mkdir build
cd build
cmake ..
make -j3
su
# make install
# exit
// Lets download and compile stargus
cd $HOME/STARCRAFT
wget http://45.76.81.249/Pinebook64/pinebook-...2.7.tar.gz
gunzip stargus_2.2.7.tar.gz
tar -xvf stargus_2.2.7.tar
cd stargus_2.2.7
mkdir build
cd build
CFLAGS="-isystem /usr/include/harfbuzz" CXXFLAGS="-isystem /usr/include/harfbuzz" cmake ..
make -j3
su
# make install
# exit
// Now we need to extract the stargus.tar data tarball and place it
// in /usr/local/share/games/stratagus/
// I have included the Starcraft data since the extraction does not
// work for me on aarch64 - it worked on x86_64 with startool
// and I believe the game is offered for free from Blizzard anyway
// Download the Starcraft Data file
cd $HOME/STARCRAFT
wget http://45.76.81.249/Pinebook64/pinebook-...targus.tar
tar -xvf stargus.tar
su
# rm -rf /usr/local/share/games/stratagus/stargus
// Copy or move the extracted stargus tarball here
# cp -rv /home/user/STARCRAFT/stargus /usr/local/share/games/stratagus
// Finally symlink the game binary
# ln -s /usr/local/games/stargus /usr/local/bin/stargus
# exit
// Play the game
stargus
P.S Please note that on higher resolutions other than 800x600
the game crashes when building a first structure ..
It seems to be stable on 800x600
The page says that it needs a 32bit host; i don't know if that means it will not work on a 64bit cpu or that it needs 32bit libraries; I should try to compile it under a Docker image (as i did with Xash3d)...
I think it's only about the libraries but I'm not totally sure either...
This probably was mentioned already, but I'll report it separately anyway:
- OpenJK works with Jedi Outcast straight from AUR(openjk-git). Unless you turn on volumetric shadows game works smoothly
- Same for Battle of Wesnoth(wesnoth-git)
- Openmw doesn't need patches anymore, thanks to Icecream95. OPENMW_DECOMPRESS_TEXTURES=1 variable is needed for it to work since Pinebook lacks S3TC compression.
(07-04-2020, 07:32 AM)brzegorz Wrote: This probably was mentioned already, but I'll report it separately anyway:
With OpenMW  did you encounter crash when exiting the Imperial ship ?
I don't; )
  Pinebook problem meghancordo 2 4,614 03-18-2026, 08:58 AM
Last Post: RicTor
  dead Pinebook - help please RicTor 2 610 03-12-2026, 04:49 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 7,851 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 641 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,228 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,202 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 3,952 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 25,492 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,029 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 6,138 01-23-2025, 11:49 AM
Last Post: Surehand53
