Pinebook pro bricked?
my pinebook pro stopped working. When I plug it in, the red light on the connector turns on, but pressing the power button does nothing. Here’s what I’ve tried:
  1. Holding the power button down for over 30 seconds
  2. Bypassing the battery by disconnecting it and bridging the two connectors
  3. Removing the eMMC and attempting to boot from an SD card
None of these solutions have worked, and the power light remains off (neither red nor green). Any assistance would be appreciated!
Were you using U-Boot or Tow-Boot on the SPI ROM?
If so, that is possibly corrupt.
If not, you are probably just having a hard time making a bootable micro-SD card. The most reliable images I've used for that are DietPi and NetBSD.
Keep in mind, that power light doesn't actually indicate that the Pinebook Pro is powered up. It is turned on in software. If the software fails, the computer locks up and the light never gets turned on.
:wq
It's also worth noting that if the PBP battery was allowed to fully drain, it can take hours to get it enough charge to boot back up. Previously, I've had to let mine charge overnight before I could get it to turn back on.
(03-12-2025, 02:40 AM)KC9UDX Wrote: Were you using U-Boot or Tow-Boot on the SPI ROM?
yea, I thought mine was bricked and it turned out the boot loader was broken. Apparently if the computer dies to quick in the process nothing turns the lights on, so it looks like your bricked. My solution was to remove the eMMC and boot from an SD card and then from the card install Tow-Boot. Maybe your issue is different, but that is what my problem was. Apparently you can hot-swap the eMMC card but I don't think you should do that unless you're desperate.
(03-11-2025, 09:04 PM)michaelmoua Wrote: Hello,
drive mad
Have you checked if the power adapter is functioning properly or tried using a different power adapter to see if that makes a difference?
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 17,303 Yesterday, 04:48 AM
Last Post: deltaexploitss
  Updated Pinebook Pro? tantamount 2 2,644 06-20-2026, 10:14 AM
Last Post: tantamount
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,973 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,650 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,123 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,077 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,177 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,054 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,403 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 30,468 03-09-2025, 11:17 AM
Last Post: davisthomas
