Problem booting Pinebook Pro
Hi!
I'd installed Manjaro 20.04 in my PBP; I did all the mirrorlist change stuff, and I shut it down 2 days ago. Today when I was going to boot it, a red light has shown and it is not opening or doing anything else.
When I try to reinstall the Manjaro 20.04 I pressed ES after 15-20 seconds and there is a black window with blank letters that say:
"[5.102225] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:84Big Grinetected aborted journal
[5.103046] EXT4-fs (mmcblk1p2): Remounting filesystem read-only"
Today I tried to disable eMMc and installing Manjaro again but the problem persists. I have only been able to mount the Default Debian image from an SD card, but I don't know how to reinstall it to the eMMc or try to boot the eMMc another way... Any ideas?
Thanks very much!
(05-03-2020, 09:47 AM)gimy16 Wrote: Hi!
"[5.102225] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:84: Detected aborted journal
Thanks very much!
Did you check the integrity of the image you downloaded? Maybe using another SD-card might help too.
Besides quoting it, you can check the "Disable Smilies" checkbox when posting or editing the post to stop it from turning :D :P &c into emoji.
(05-18-2020, 04:55 PM)waweic Wrote: Did you check the integrity of the image you downloaded? Maybe using another SD-card might help too.
I tried to use another image and using another SD-card, the result was the same.
Then I contacted with the Pine64 support, and finally they said that it could be problem of the motherboard and that I had to change it.
Finally I got an USB to eMMC adapter from Pine64, I connect thee eMMC of my PBP to my PC and it was empty! So I downloaded the Manjaro image again, and I installed it into the eMMC using etcher; probably I did something wrong in order to erase all the data froom the eMMc; but now it's solved!
Thanks to all the community for the support!
  Pinebook Pro for sale rfm83 0 325 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,805 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,833 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,125 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,698 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,059 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 3,937 03-31-2025, 07:14 AM
Last Post: Anarethos
  Use SD to install new OS over pinebook debian Rudy558 10 23,349 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,674 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,561 01-23-2025, 11:49 AM
Last Post: Surehand53
