Charging problem
Occasionally when booting up the PBP, charging does not start up. The PBP can then totally discharge its battery. This happens when the battery is full, having been on charge all night. It is not predictable!
I have been investigating and think I have found what  is happening - hence how to trigger charging. But I don't know why!
Anyone else have the problem?
Are there any experts here who know the power / charging system? I can use help understanding the  schematic...
You might want to ask a professional. When I had a problem with my circuit diagram before, I reached out to a technician at PCBWDX, and he answered my question right away.
https://www.pcbwdx.com/
Could this be a sign of a worn-out battery? Besides that, it's likely your battery is faulty. How long have you been using it?
I had a similar problem, the shipped barrel charger became unreliable. Had to switch to charging from the USB port and that solved it for me.
(07-22-2026, 05:46 PM)WEF Wrote: I had a similar problem, the shipped barrel charger became unreliable. Had to switch to charging from the USB port and that solved it for me.
Charging using USB-C port somehow resolve this issue as you have indicated.
  PineNote v1.2 - Charges Never Enter "Charging" State (Factory OS, RK817 Below Minimum ttsp 0 1,638 07-02-2026, 02:52 AM
Last Post: ttsp
  Pinebook problem meghancordo 2 7,270 03-18-2026, 08:58 AM
Last Post: RicTor
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 7,095 03-31-2025, 07:14 AM
Last Post: Anarethos
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 6,657 02-05-2025, 03:56 AM
Last Post: waylonwesley
Photo P{inebook Pro not charging Ome Ko 6 7,571 11-09-2023, 03:29 PM
Last Post: tomekdev
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,892 02-21-2023, 01:49 AM
Last Post: repa
  Pine Book Pro Charging Problems balin 7 14,422 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Problem SD card willahughes 1 4,060 03-22-2022, 09:27 AM
Last Post: jiyong
  Very low battery (but charging) causes boot failures Phillip Bell 7 11,297 02-22-2022, 11:20 AM
  very strange .pptx highlight color problem stozi 0 2,712 09-02-2021, 02:50 PM
Last Post: stozi
