(04-14-2020, 10:12 AM)Ardent Wrote:
(04-14-2020, 09:19 AM)mamboman777 Wrote:
(04-14-2020, 08:23 AM)Ardent Wrote:
(04-13-2020, 09:56 PM)inspiredrat Wrote: How frequently should my install be getting updates?  I've been using the updater through KDE discover and haven't had any for a while now.
You may need to switch to the new mirror list: https://forum.manjaro.org/t/another-mirr...red/132302
I just followed the instructions on the thread and now my Pinebook Pro will not boot.  It seemed as if the updates ran correctly from the terminal.  When I tried to reboot the only thing I get is a red light.  Can you please let me know what next steps might be in troubleshooting?
Ah sounds like this issue: https://forum.manjaro.org/t/arm-stable-u...s/133266/2
Great...I wish i knew that before I rebooted...I guess the solution is to pull the emmc and use the usb adapter.
I can confirm this fixed my issue.  My next question is, why on earth is this on the stable channel if it bricks systems?
Well...now booting from SD is an issue. Anyone know why that would be a problem now?
(04-14-2020, 03:09 PM)mamboman777 Wrote: Well...now booting from SD is an issue.  Anyone know why that would be a problem now?
I think non-bootable SDs is known Manjaro issue you might want to look into the Manjaro forums searching the posts?  If not then I too would like to known the answer to your problem as I have it not working too.
Ne quid nimis
The work around is to roll back the U-Boot.  Look on the 1st page of this thread.  brent.thierens posted the fix.
I'm wrong, it's this thread: https://forum.pine64.org/showthread.php?...0#pid64250
I knew about the u-boot rollback trick and already applied it thanks.   I can boot some distros e.g. Q4OS, Debain, and Manjaro.  However I still can not boot some other distros e.g. Bionic Mate, Armbian, and Chromium.  Those that failed all booted with Debian on the eMMC.  Maybe its something on my end I would be interested if others are having any boot SD issues across more distros like I have done.  I should add that I'm using the latest Manjaro for these boot sd tests e.g. 20.04 download directly from Manjaro URLs.
Ne quid nimis
Just to help, I'll explain the simple version of how I fixed the no-boot issue following the upgrade to Manjaro ARM 20.
You need to change this file before restarting as per the post: https://forum.manjaro.org/t/arm-stable-u...s/133266/2
If you forget to do this and it doesn't boot then download the (non-emmc install version) of Manjaro ARM live version here: https://osdn.net/projects/manjaro-arm/st...04.img.xz/
Then format an SD card to ext4 with Gparted and use BalenaEtcher to flash the image to the SD.
Restart the Pinebook with the SD card inside, create the user and password on the SD and when it boots in go to the ROOT filesystem of the EmmC itself and using Kate edit the /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash. Save the file then shut the laptop down. Take the SD card out then restart the laptop as normal - it will boot fine.
I know this was simplistic, but I think it will give clarity to some about how to fix this issue simply and easily as there is a lot of misleading info out there on this.
Hope it helps.
I think the process you are describing is for upgrading and fixing booting from eMMC for 19 to 20.04.
Are you saying this fixes booting from all other distros using SD card?
Sent from my iPhone using Tapatalk
Ne quid nimis
(04-18-2020, 10:07 AM)mtlemmonrunner Wrote: I think the process you are describing is for upgrading and fixing booting from eMMC for 19 to 20.04.
No the above fix is only for upgrading from old releases as we are now using dual partition method for all the devices.
To fix booting from other OS over sd is a fix needed to be implemented by the other OS maintainers.
Manjaro ARM Team.
Hi!
I tried getting help on the Manjaro forum with this post (https://forum.manjaro.org/t/cant-run-ima...ght/135853) but still couldn't get a solution for my problem, so I decided to try my luck here. Here's the problem:
I haven't been able to run the latest versions of Manjaro on the Pinebook Pro's eMMc.
Here's what happens with different installer eMMc images to the eMMc:
19.12 XFCE - installs, runs smoothly, updates to the latest version
19.12 KDE - installs, runs smoothly, updates to the latest version
20.02 XFCE and KDE - copies files from SD to eMMc, but on restart, no more than a black screen with orange light in the keyboard;
20.04 XFCE and KDE - same as version 20.02
Other aspects to this install failure:
- SD slot becomes unusable as well: can't boot anything from the SD
- only after removing the eMMc can I boot from the SD, but only an 8GB SD; i've tried two 32 GB SDs but they won't boot.
Other facts:
- SD installs of Manjaro do run fine, all of them
- I tried both dd and etcher to build the images
- I edited the file in /boot/extlinux/extlinux.conf to include the two dots as instructed
(04-18-2020, 10:09 AM)spikerguy Wrote: No the above fix is only for upgrading from old releases as we are now using dual partition method for all the devices.
So if I understand, you do not need to do the fix if you are installing Manjaro to eMMC when the eMMC has an OS other than Manjaro (eg. stock Debian), and the fix is only necessary if installing over an older Manjaro?
Then is there a way to boot current other OS from SD?
  Boot Order in Pinebook Pro food 12 13,722 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,559 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,949 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,281 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,845 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,542 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,818 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 108,575 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,802 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,386 03-31-2024, 10:11 AM
Last Post: u974615
Users browsing this thread: 7 Guest(s)
