Manjaro won't boot (again)
Hello everybody,
just received my pinebookpro yesterday: a rapid glance at the default OS: all works well.
Then I installed Manjaro ARM KDE edition 20.02.1 with the emmc installer. Everythin is OK, but after a shutdown the new system doesn't start.
Here's what I do:
  • push the start button
  • the led turns orange for a while
  • becomes green but nothing happens: the screen is black.
Very strange behaviour indeed!
To be honest, the pinebookpro started for another time with manjaro. So, just to try, I rebooted: it started again. Then I shutdown. Now I can't restart again.
What would you suggest?
Marco
Do you have enough energy on pbp?
Many times I forgot that pbp is on resume mode and battery is empty, so I need to plug charger AC to boot... XD
yeah, full battery here, and ac power connection too...
I would suggest:
as soon as possible, make/get yourself a bootable SD card for the Pinebook Pro.
Maybe the PBP would boot from the SD Card when it won't boot from internal emmc.
As for how to make a bootable SD card (especially if you can't boot the PBP to do it from there), I don't have a link to a good set of instructions handy, but I expect any of the "DD images" linked from https://wiki.pine64.org/index.php/Pinebo...re_Release would be a thing you could use.
Yep, you need various sd cards to test differents versions of OS for pinebook.
To install into emmc, use manjaro emmc installer instead dd from sd card.
In your case perhaps your sd card is bad burned or similar...
Try with one new or different.
i am probably tinkering more than the normal user, but having several sdcard installs has been not only useful and interesting, but has saved me from self-inflicted disaster a few times. having an emergency option with sdcard is awesome.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,783 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 11,562 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,206 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,729 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,051 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 3,218 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,559 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,881 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,077 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,154 12-11-2023, 03:47 AM
Last Post: calinb
