An unofficial Debian Installer for Pinebook Pro
#81
(01-17-2020, 03:28 AM)danielt Wrote:
(01-16-2020, 09:40 PM)rillian Wrote: Where is a good place to keep track of bugs related to the Bullseye image? Maybe on the installer github project? It's easy for issues to get lost on the forum, but filing directly with Debian or upstream makes it hard for Pinebook community members to see the status of thing.
Issues on github is fine but I'll probably close anything that isn't caused by a bug in the installer or the kernel. IMHO upstream bugs belong in upstream bug trackers.
I'm also of the view that bug trackers aren't the best way to see the overall status of things. They focus exclusively on what doesn't work, which can be pretty misleading.
Better IMHO to create a wiki page for the release and create tables of what is and isn't work plus perhaps some free form notes to transient upstream issues (such as the firefox problems). Not only is that more useful for users but it can also be curated by anyone in the community who interested in compiling and maintaining such information! If someone does put together such a page I'd be happy to link to it from the first post.
What about having the wiki enabled in the github repo?
#82
(01-16-2020, 11:59 PM)NigelT Wrote: The block device names are as follows:
mmcblk1 = internal eMMC device
mmcblk0 = microSDXC card
However, once booted into Debian bullseye/sid, those devices have different names
mmcblk2 = internal eMMC device
mmcblk1 = microSDXC card
Note how mmcblk1 can either be the internal eMMC or the MicroSD card.
Good point.
We could perhaps point the default at /dev/disk/by-path/platform-fe320000.dwmmc instead (and add some code to follow the softlink). What name does the uSD card appear at under /dev/disk/by-path when running with the default Debian 9 kernel?
dptx.bin loading works OK for me meaning the (D)isplay (P)ort (TX) over USB-C works ok for me ;-)
I think this is because I have a slightly customized install where only /home is encrypted. As a result although the first two load attempts fail the firmware does loads on its third try after the rootfs is mounted. Anyone with an encrypted rootfs will have problems because the third try will take place during the rootfs decrypt prompt and will also fail.
Ultimately this is causes because the drm module is built into the kernel so the initramfs tools cannot find it: https://bugs.debian.org/cgi-bin/bugrepor...=857054#10
There is a hack further up in the above bug report showing how to add an initramfs hook to ensure the dptx.bin firmware gets included in the initramfs. If you have have problems with this firmware loading then please experiment with that and report back!
(01-17-2020, 04:21 AM)e-minguez Wrote: What about having the wiki enabled in the github repo?
I will if that's where people are happiest editing it but personally I was thinking of a page on the pine64 wiki.
As discussed in the Roadmap I rather hope that upstream Debian (and the PBP bootloaders) will improve to the point my installer becomes obsolete. At that point a wiki page on pine64 wiki would, as I remove obsolete hacks from the installer, end up describing the upstream status.
#83
Wiki page started here -> https://wiki.pine64.org/index.php/Pinebo..._Installer
Linked in the software release one (https://wiki.pine64.org/index.php/Pinebo..._Installer)
HTH!
#84
(01-17-2020, 04:30 AM)danielt Wrote: We could perhaps point the default at /dev/disk/by-path/platform-fe320000.dwmmc instead (and add some code to follow the softlink). What name does the uSD card appear at under /dev/disk/by-path when running with the default Debian 9 kernel?
Default OS / Kernel
$ uname -a Linux Debian-Desktop 4.4.207 #2 SMP Sat Dec 21 22:42:47 EST 2019 aarch64 GNU/Linux
Empty microSD cart slot
$ ls -l /dev/disk/by-path/platform-fe320000.dwmmc ls: cannot access '/dev/disk/by-path/platform-fe320000.dwmmc': No such file or directory
After inserting an microSD card
$ ls -l /dev/disk/by-path/platform-fe320000.dwmmc lrwxrwxrwx 1 root root 13 Jan 17 12:52 /dev/disk/by-path/platform-fe320000.dwmmc -> ../../mmcblk0 $ readlink -f /dev/disk/by-path/platform-fe320000.dwmmc /dev/mmcblk0
#85
Running the script to install on my sdcard
./home/rock/pinebook-pro-debian-installer/install-debian BLKDEV=/dev/mmcblk0
 I run in the following error while building initramfs:
find: '/lib/modules/5.4.2-2-pinebookpro-arm64/kernel/arch/*/crypto: No such file or directory
repeated 8 times
followed by
depmod: ERROR: ../libkmod/libkmod.c:515 lookup_builtin_file() could not open builtin file '/var/tmp/mkinitramfs_RANDOMSTRING/lib/modules/5.4.2-2-pinebookpro-arm64/modules.builtin.bin
repeated A LOT of times
The generated image shows splash screen followed by a black screen with randomly blink cursor in upper left screen. If I quickly switch terminals (CTRL+ALT+F1..12) sometimes I can see some kernel messages (with some ERROR strings) or a login prompt, both quickly replaced by the black screen with cursor.
The 'find' command is right: /lib/modules/5.4.2-2-pinebookpro-arm64/kernel/arch contains only 'arm64/lib/xor-neon.ko'
When the second error is produced, the /var/tmp is already empty, so I cannot check.
The two tests above are performed in the chroot environment (/home/rock/pinebook-pro-debian-installer/sysimage is mounted as /).
The script repository is updated with last commit (1f1065a).
Am I doing something wrong or missing something?
#86
Which version of Debian does this install?
#87
(01-17-2020, 05:05 AM)e-minguez Wrote: Wiki page started here -> https://wiki.pine64.org/index.php/Pinebo..._Installer
Thanks! I'll add issues there are I find them.
#88
Regarding the failed firmware load of dptx.  (Direct firmware load for rockchip/dptx.bin failed with error -2)
(01-17-2020, 04:30 AM)danielt Wrote: Anyone with an encrypted rootfs will have problems because the third try will take place during the rootfs decrypt prompt and will also fail.
I think maybe everyone will have problems regardless of encryption.
My system doesn't have any disk encryption and the firmware is present in rootfs (/lib/firmware/rockchip/dptx.bin)
But an initrd is present /boot/initrd.img-5.4.2-2-pinebookpro-arm64 that doesn't contain dptx.bin
It seems the kernel only looks in the initrd (or rootfs appears too late), so regardless whether /lib/firmware/rockchip/dptx.bin is present in the rootfs or whether rootfs is encrpted or not, it won't find/load dptx.bin unless it's in initrd.
In case anyone is interested, this is how I added dptx.bin to the initrd on my bullseye/sid installation.  (disclaimer, there is probably a better way to do this)
First check initrd for dptx
gzip -dc /boot/initrd.img-5.4.2-2-pinebookpro-arm64  | cpio -t | grep dptx 74917 blocks
If dptx was not shown (like the example above) and you want to add it, then add a hook script to automatically copy it from roots to initrd when initrd is updated
vi /etc/initramfs-tools/hooks/add-dptx-firmware
#!/bin/bash [[ "$1" == prereqs ]] && exit 0 . /usr/share/initramfs-tools/hook-functions copy_file firmware /lib/firmware/rockchip/dptx.bin
The script has to be executable or it is ignored.
chmod +x /etc/initramfs-tools/hooks/add-dptx-firmware
If you don't have /lib/firmware/rockchip/dptx.bin present in rootfs, install package "firmware-misc-nonfree"
Update initrd and check it contains dptx
# update-initramfs -u # gzip -dc  /boot/initrd.img-5.4.2-2-pinebookpro-arm64 | cpio -t | grep dptx usr/lib/firmware/rockchip/dptx.bin 75115 blocks
Great it's present.  Now reboot.
For me this was necessary so I could use a USB-C to HDMI adapter to connect an external monitor.
#89
(12-04-2019, 03:34 AM)danielt Wrote: I've recently spent a little while hacking together a quick 'n dirty Debian installer for the Pinebook Pro.
https://github.com/daniel-thompson/pineb...-installer
It is not a fully fledged installer... just some code that run on the Pinebook Pro itself using an existing Debian (or maybe Ubuntu) distro. It will install an operating system from scratch to an alternative media. Nevertheless it is a "real" installer in that sense that there is no downloadable image, no default password and you get to choose the keyboard layout, locale, timezone and desktop environment for yourself!
Hi @danielt,
Have you looked into / are you interested in getting the offician Debian Installer running on the PBP?
This might be a good start:
https://lists.debian.org/debian-arm/2020...00009.html
Have fun Big Grin
#90
I've done some Octane2 benchmarks using the arm64 install for reference:
Note: firefox and chromium installed from unstable using apt pinning, and benchmark score is best of 3.
firefox-esr, 68.4.1, armhf, 7906
firefox, 72.0.1, arm64, 5269
firefox, 72.0.1, armhf, 7937
chromium, 79.0.3945.79, arm64, 9991
chromium, 79.0.3945.79, armhf, 9550
Notes:
chromium arm64 crashed once during benchmark
  Boot Order in Pinebook Pro food 14 20,089 11-16-2026, 01:09 AM
Last Post: NorrisFByrd
  Window Maker Live for Pinebook Pro vajak 9 6,782 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,430 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,386 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,910 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 125,942 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,946 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,730 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 18,096 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,550 12-13-2023, 07:22 PM
Last Post: trillobite
