Is it possible to install Arch linux?
Hi everyone!
I just recieved my new pinebook pro; last one was already stolen from me, just a few days after it came by mail! Crazy story. If anyone sees a pinebook pro on sale around Paris, please let me know; might be mine.
Anyway, I am now finally able to hack on this beauty again.
I'm running Manjaro for now, but I would much prefer a more minimalistic approach. How could I install Arch linux (Arm) ?
I have seen there has been quite some work to get Manjaro running on PBP, so I guess it will be harder than simply installing Arch linux arm - pine64 version (https://archlinuxarm.org/platforms/armv8...ner/pine64) . Or is it that simple? If it is not; which hurdles can I expect and clues on how to fix thoses? I guess many distros will have to do this work in the coming weeks; is there a place to document theses procedures?
Even Minimal Manjaro could work for a period; but I did not succeed at booting it from an SD card using this install script: https://gitlab.manjaro.org/manjaro-arm/a...-installer . I suppose it is not supported yet; seeing there are no prebuild minimal images for the PBP; just XFCE and Plasma images.
https://manjaro.org/download/#pinebook-pro . But it could also very well be a wrong manipulation on my side. has anyone successfully run the minimal Majaro install on the PBP ?
Thanks to everyone for any info, and thanks to the Pine team for such an amazing hardware.
Best of luck for 2020.
(01-01-2020, 06:10 PM)alxndr.psclt Wrote: Hi everyone!
Do not use a pine64 image on the PBP, it will not boot. The PBP is different hardware from that board (RK3399 vs A64.)
To get minimal Manjaro, your best bet is to likely boot from a Manjaro live disk and use manjaro-arm-installer to create the minimal image. If you'd really like ALARM, check out their wiki. The Rock64 is a less robust cousin to the guts of the PBP, so you could likely get it working on the PBP.
I would suggest using one of the u-boot images here, and not mainline though, as I believe mainline u-boot has a boot priority of eMMC, then SD.
Thanks for the info, this is what I did and it works ok.
My understanding is that when the pinebook pro changes are upstreamed to the kernel, it will be easy for most distros to support the PBP? Is this valid reasoning?
  Can’t login to Linux fnosai 0 3,172 07-27-2025, 12:30 AM
Last Post: fnosai
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,108 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,031 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 6,681 02-09-2025, 02:58 PM
Last Post: mikehenson
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,229 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,622 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 3,898 06-05-2024, 04:30 PM
Last Post: vxzero
  By the way, yay arch... KC9UDX 4 5,821 03-30-2024, 10:27 PM
  install debian on pbp jsch 7 11,990 11-22-2023, 04:22 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 7,212 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
