#81
(11-25-2019, 05:48 AM)Feakster Wrote: Manjaro Preview 4 is out now:
Fully working bluetooth
Fixed Wifi instability
Did, the pacman upgrade. Bluetooth works for me, but Wifi crashed twice, each time I managed to get it back by power-cycling with the privacy switch and then doing the unbind/bind trick.
#82
Can I use Nightlight in sway? What is the name of the package or does it come with KDE/GNome Shell? That would be overkill to install.
#83
(11-26-2019, 07:17 AM)lispy Wrote: Can I use Nightlight in sway? What is the name of the package or does it come with KDE/GNome Shell? That would be overkill to install.
I think it's part of Wayland, looks like it might be available as part of Sway. Yup, it's mentioned on their wiki.
#84
Using KDE moved from XFCE I have not yet made my mind. I likely will reinstall when out of preview. Using now a bluetooth mouse .... it feels good Smile
Wifi has been stable too and the touchpad without click for left click has been nice to have, I had to reinstall preview3, and update from preview2 was not enough.
#85
Please disable 'sdio-hciattach'
sudo systemctl disable sdio-hciattach
This should help with wifi. If not please report back
Thank you.
Manjaro ARM Team.
#86
I really like how dim the screen can get with KDE and that it can turn off the backlight completely.
Perfect to get the last ounce of battery life from the device Big Grin
#87
(11-26-2019, 01:02 PM)spikerguy Wrote: Please disable 'sdio-hciattach'
I don't even have a sido-hciattach.service.
Seem that the trouble are firmware-related: I followed tsys' advice and fetched the latest firmware from gitlab and haven't seen a crash yet.
#88
Thanks to @"Feakster" (I hope it's the same user Smile ) for pointing out that USB-C video out is working now on the Manjaro forum!
So, from the basics I'm only missing separate headphone and speakers output now Smile
#89
(12-04-2019, 05:01 AM)PakoSt Wrote: Thanks to @"Feakster"  (I hope it's the same user Smile ) for pointing out that USB-C video out is working now on the Manjaro forum!
Tis indeed.
#90
i just get a mirror image no extended monitor
  Boot Order in Pinebook Pro food 12 19,020 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,472 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,217 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,648 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,338 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,450 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,622 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 123,184 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,747 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,436 03-31-2024, 10:11 AM
Last Post: u974615
