#61
@pcm720 what's your Sway setup?
#62
After messing around with KDE+Wayland, and being annoyed by the white overlays given to every window/notification, I thought "why the hell not?" and installed Gnome 3. I have to say, I'm VERY impressed by how responsive it has been! I expected it to be bloated and sluggish, as my previous experience with Gnome 3 on lower spec hardware has been. However, it's snappier than KDE+Wayland, there's not been any annoying overlays, and trackpad emulation works very well! (Though for some reason, when using tap-to-click, the lower right of the trackpad, which works as the right click in every other OS I've tried, does not. You have to do the two finger tap.)
I think Gnome 3 might actually be a good DE option to give to the Manjaro PBP images. (Though I understand if the great people maintaining them don't use Gnome or feel like fooling with it.)
#63
(11-18-2019, 07:35 AM)tophneal Wrote: After messing around with KDE+Wayland, and being annoyed by the white overlays given to every window/notification, I thought "why the hell not?" and installed Gnome 3. I have to say, I'm VERY impressed by how responsive it has been! I expected it to be bloated and sluggish, as my previous experience with Gnome 3 on lower spec hardware has been. However, it's snappier than KDE+Wayland, there's not been any annoying overlays, and trackpad emulation works very well! (Though for some reason, when using tap-to-click, the lower right of the trackpad, which works as the right click in every other OS I've tried, does not. You have to do the two finger tap.)
Do you have the steps to install Gnome3?
Sent from my PH-1 using Tapatalk
#64
It was pretty simple, I just ran sudo pacman -S gnome
I intentionally left out gdm, as I wasn't sure if I didn't know if Gnome was worth keeping around. I also had some issues trying to install gnome-extra and didn't spend time tracking it down, but it's worth adding that to the install if you want the full switch.
After the install was complete, I logged out and chose Gnome (Wayland) from sddm.
#65
I'm using gnome 3 and runs properly.
Gnome-extra has a dependence bug and can't install, you need to install single package of gnome-extra if you want it.
My pinebook pro system is using manjaro arm gnome 3 using emmc.
Goes very good in comparision with rest of distros.
#66
(11-19-2019, 03:25 AM)erchache2000 Wrote: I'm using gnome 3 and runs properly.
After discussing it with Strit, I've decided to just install individual packages from the group. When I looked up a list of packages in gnome-extra, it was mostly games. No thanks.
#67
Well, no surprise, that's what Alyssa Rosenzweig (one of the main developer of Panfrost) runs on her ARM Chromebook so Panfrost is going to see a little bit more testing on Gnome than other DE.
#68
(11-18-2019, 04:00 AM)PakoSt Wrote: @pcm720 what's your Sway setup?
I'm using waybar, wofi, mako and termite, all themed around Adwaita-dark with Google's Noto Sans as main font.
I also removed XFCE altogether and installed GNOME instead. IMO, GNOME apps look better with tiling WMs.
Here's how everything looks:
https://imgur.com/a/O5MEoDV
#69
@pcm720 , that's really awesome setup!
#70
Tried Gnome out the other evening. Responsiveness wasn't great when navigating through all the Gnome menus, but the window movement was smoother than on my much more powerful laptops. Very impressive!
The three main problems I have with Manjaro ARM right now are getting hardware acceleration to work in Chromium so that 1080P videos are playable on YouTube, the lack of 5 GHz WiFi, and the lack of suspend. Based on the rapid progress so far, I'm quite hopeful that these issues will be resolved in the coming months!
  Window Maker Live for Pinebook Pro vajak 8 1,547 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,447 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,783 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 11,562 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,207 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,729 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,052 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 99,371 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,429 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 9,338 03-31-2024, 10:11 AM
Last Post: u974615
