Installing Wifi drive for the RockPro64
I am trying to install Debian on the RockPro64 and I am having trouble getting the wifi drivers to be recognized by the installer. Without these I can not finish installing the OS.
At present I have tried formatting a USB stick to FAT32 and adding the files from here to a folder named "firmware" on the USB stick however the installer can not identify these files and keeps throwing an error stating the following files are missing:
brim/brcmfmac43455-sdio.bin
brim/brcmfmac43455-sdio.pine64,rockpro64-v2.1.bin
I can't install the OS without getting the wifi working so I am not entirely sure how to go about rectifying this problem. Does anyone have any suggestions? Should I be using a different OS? Is it a requirement to have a wired internet connection when you first install Debian?
If there are no other options I can go somewhere with a wired connection and install the OS and try and get the wifi firmware installed once the OS is already installed however I would like to avoid that if possible.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,502 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,238 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,581 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,287 11-26-2024, 11:08 AM
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,977 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,716 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,467 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,038 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,374 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 8,241 03-19-2023, 06:22 AM
Last Post: runyor
