How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card
I connected a PCI NVMe adapter to the RockPro64, but nothing is added to
/dev/sd*
 or
/dev/nvme*
. The products I tested are as follows:
PM9A1 500GB
FireCuda530 2TB
What could be the problem?
os : Armbian_24.5.1_Rockpro64_noble_current_6.6.31
Well, I have a pci card and nvme drive.... so...
dmesg |grep pci should be almost a full page,
the last line mentions nvme
and dmesg |grep nvme should be 5-6 lines
Maybe the pci card is not compatible, OR it is not a nvme type of m2 drive
Cheaper m2 drives are nearly always SATA, this will NOT work
  RockPro64 automatically run after power recovery - my solution g2t 1 1,839 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,525 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,856 03-28-2025, 11:15 PM
Last Post: john_nash
  Installing Wifi drive for the RockPro64 John45595 0 4,810 02-10-2024, 11:32 PM
Last Post: John45595
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 229,598 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,322 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,982 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 14,066 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,276 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,674 04-06-2023, 02:46 PM
