Manjaro update, no boot, just noise.
I recently updated Manjaro Plasma and now I have an unbootable phone that just vibrates loudly.
Video posted on Mastodon here...
PPP sounding like hair clippers.
Don't know if it's a lost cause or not. Any ideas?
(05-08-2022, 06:41 AM)wilmarcdw Wrote: I recently updated Manjaro Plasma and now I have an unbootable phone that just vibrates loudly.
Either a bug or the vibration motor is shorted, both quite possible. My guess is that the installation is corrupted and it is getting stuck at boot at a step with the vibration.
Please simply boot another OS via microSD card. Rough steps:
  1. Prepare a microSD card as explained on the wiki
  2. Insert the microSD card into the phone (top slot, card inserted all the way)
  3. Hold the "RE" button
  4. Power on the phone while still holding "RE" (30-60 seconds), it will boot into the microSD card if it is flashed and inserted correctly
  5. Overwrite the eMMC installation
The steps can be found here: https://wiki.pine64.org/wiki/PinePhone_Pro#Software
I would recommend you to flash https://github.com/manjaro-pinephone/pla...e/releases (select the image for the Pro, not the regular PinePhone).
Make also sure to join the bridged community chat, such issues are quick and easy fixed there, while questions and replies on the forum can take some very long time. Link to the chat can be found here: https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms
Thanks.
I must be getting senile in my old age. The wiki does cover the situation (troubleshooting) but not sure why I didn't check. Also on been on the pinephone matrix channel for some time. Oops.
Anyway, other than some dumb typing mistakes causing delays and issues, Manjaro Plasma is back on the emmc. Also installed tow-boot and have Manjaro Phosh on card. With both working well, so far, I'll put it back on the keyboard and get back to business.
Thanks again.
EDIT:  Performed an update while composing. That all went well, too, this time.
Cool
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 8,981 02-25-2025, 08:27 AM
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 9,411 12-19-2024, 05:22 PM
Last Post: dukla2000
  Manjaro plasma mobile Wifi Uturn 2 3,498 12-05-2024, 12:46 AM
Last Post: Uturn
  tow-boot installation problem techariah 4 7,646 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 6,021 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 4,901 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 101,884 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 10,972 02-02-2024, 07:07 PM
Last Post: reky
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 1,993 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,096 10-14-2023, 11:57 AM
Last Post: mburns
