Manjaro plasma mobile Wifi
Manjaro plasma mobile (edge) disconnects Wifi every seconds, asking again for WPA password. Somehow given passwords do not seem to get stored where they should or something... Also in the wifi setings trying to connect results in recurring a password popup. Is there a way to fix that behaviour?
Actually, wifi connects but immediately disconnects, system messages *no secrets were provided* followed by a new request for WPA password.
(12-04-2024, 12:58 AM)Uturn Wrote: Manjaro plasma mobile (edge) disconnects Wifi every seconds, asking again for WPA password. Somehow given passwords do not seem to get stored where they should or something... Also in the wifi setings trying to connect results in recurring a password popup. Is there a way to fix that behaviour?
try to create /etc/modprobe.d/brcmfmac.conf as superuser (root) and write following line into it.
Quote:options brcmfmac feature_disable=0x82000
Then reboot.
Then reboot.
I arrived in opening that folder with the file viewer *index* and it was empty, but i am not able to run index as root (yet). However that folder is empty.
now arrived in running index as root, but filename displays *brcmfmac>conf* instead *brcmfmac.conf* as the *.* key returns an *<*.
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,156 01-02-2025, 09:21 AM
Last Post: pineconeuser
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 6,129 04-15-2024, 08:08 AM
Last Post: u-kidjp
  Can't configure APN/Have no mobile internet zvavybir 4 5,932 11-22-2023, 12:11 AM
Last Post: zvavybir
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 2,822 11-09-2023, 07:39 AM
Last Post: mburns
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 6,399 07-20-2023, 11:19 AM
Last Post: mburns
  Manjaro Plasma unstable branch glitch mburns 2 3,977 06-21-2023, 08:03 AM
Last Post: mburns
  Manjaro as shipped & camera? hambonius 1 3,062 06-20-2023, 02:26 PM
Last Post: fxc
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 3,565 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 7,017 06-05-2023, 09:24 PM
Last Post: Barugon
  Is Manjaro Plasma stable for anyone? projectcato 120 132,114 04-18-2023, 08:26 PM
Last Post: mburns
