Brand new Pinecil worked for 30mins - now screen dead and glows red hot!
I've seen many similar posts - but thought I'd add my experience in the hope this gets escalated and flagged.
New Pinecil - using USB-C. Worked perfectly using USB until it said low power. Then switched over to barrel PS 12V. Again, working for 20 mins. Then, the screen went blank and the unit became unresponsive. The body becomes warm when connected to Max laptop USB (when I tried to connect with the latest firmware updater - no connection). Nothing with USB-C. Glows red hot when connected to the barrel PS. A fire hazard(!).
I've submitted a ticket and will report back with progress.
It's disappointing to hear this is so common. I wish I had checked this forum before buying the unit.
Cheers, Paul
Exact same thing happened to me work great for the first two three hours the next day red hot I thought it was cuz I tried a different tip but it's common now I don't know why they're not posting any type of corrective action
(02-06-2022, 05:24 PM)clipclop Wrote: I'd add my experience in the hope this gets escalated and flagged.
Why not contacting the store support?
And:
When you order directly via pine64.com, you get 30 days warranty. Claim your warranty, and encourage all others to do so, too. So they will have costs as long as they do nothing about it.
(I am just waiting to receive mine, let's see.)
Live volunteer active channel is in discord but has bridge to other comms too. many of the most active volunteers don't check these forums, it is a fluke I happen to be in here today looking for something else.
Links to join live Pine64/pincil chat is in Pinecil Wiki Pages. https://wiki.pine64.org/wiki/Pinecil#Community_links
Once you submit your ticket to support come to live chat and volunteers around will help you diagnose. Good to have Specs on your Charger exact specs Volts/amps/watts, and also having a Multimeter around will help too.
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 528 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 782 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,100 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,727 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,506 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,147 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,710 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
  Pinecil constantly cutting out WroughtIron 1 2,574 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,797 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,386 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
