Pinecil V2 screw broken!
Sad
I have been using my Pinecil V2 without issues for half a year now, but when changing the tip I managed to break the screw after tightening it Sad. In the picture below, I have photographed the broken screw.
[Image: YctiSOe]
I also tried opening the case and removing the tip, but I could not do that because the broken screw was tightened and was holding the tip in place.
What can I do? How can I replace the screw?
I see that the picture did not link well, here's the actual link: https://imgur.com/a/YctiSOe
  pinecil v2 dosent negotiate power moses 0 1,671 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,106 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,541 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,766 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,462 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,879 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,397 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,251 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,180 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,188 05-15-2025, 10:41 AM
Last Post: dreieck
