my pinecil v2 is not working
If I connect to a power supply, the display only shows calibrating, and not work. If I push the + switch under connecting the power,
it shows PD debug State 3 No Vbus. After push the - switch, only shows calibrating...
Under firmware update there are handshake errors. So I cannot step through the "calibrating" word.
The display orientation is changes, as I turn the pinecil handle to other direction....
How do I reset the unit to a working state?
  pinecil v2 dosent negotiate power moses 0 1,377 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 947 06-21-2026, 02:53 AM
Last Post: davidcoley
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,560 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,326 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,750 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,190 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,101 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,016 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 6,879 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 2,186 05-15-2025, 01:35 AM
Last Post: autumnharris
