Pinecil v2 issue
I recently bought a Pinecil V2 to learn how to solder. I'm using the USB-C cable from the website along with a Samsung EP-T6530 power adapter. When I connect the Pinecil to the top 65W port and power it on, everything works fine, showing 20V without issues. However, as soon as I start heating it up, it shuts off when it reaches the desired temperature.
I tried using the 25W port, and while it didn’t shut off, it only shows 11V, making it difficult to melt solder. I’m wondering if I’m doing something wrong or if my adapter isn’t sufficient. Does anyone have any suggestions on how to resolve this issue?
  pinecil v2 dosent negotiate power moses 0 1,710 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,128 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,562 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,817 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,489 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,899 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,444 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,279 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,209 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,247 05-15-2025, 10:41 AM
Last Post: dreieck
