Pinecil v2 not reaching 20v …
I just bought a Pinecil v2 and updated to firmware 2.23
and it also checks out to be official via the website check.
I bought the Amazon Basics 65W One-Port GaN USB-C PD 3.0
charger which is on the pine64.org list of 20v chargers but it only
goss up to 15v. When I play with the settings I can get it to reach
20v only when PD Mode is set to normal. So the default mode
„no dynamic” as well as „safe mode” only go to 15 volts …
Is that normal?
  pinecil v2 dosent negotiate power moses 0 1,187 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 867 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,255 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,423 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,264 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,670 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,099 10-16-2025, 10:40 PM
  Pinecil v2 tip screw temperature Minuen 0 9,879 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 6,649 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 2,112 05-15-2025, 01:35 AM
Last Post: autumnharris
