Minimum temperature Pinecil
I’m looking voor the lower bounds on temperature for the pinecil, but can’t seem to find it mentioned explicitly.
I want to use it to melt wax at 65 degrees Celsius.
All I could find was the temperature control might not be as accurate below 150 degrees.
Looking forward to your responses
(10-12-2025, 03:14 AM)pschalkwijk Wrote: Hi,
I set my Pinecil to 65 degree and seems like able maintain at that level with few degrees tolerance (sometime jump to 70).
  pinecil v2 dosent negotiate power moses 0 1,377 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 947 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,357 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,560 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,326 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,750 12-03-2025, 07:40 AM
Last Post: jamespo
  Pinecil v2 not reaching 20v … Escape75 0 5,101 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,016 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 6,879 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 2,186 05-15-2025, 01:35 AM
Last Post: autumnharris
