Help with Pinecil
I recently purchased a Pinecil to repair my headphones.
Before tackling the headphones, I practiced soldering jump wires to a proto board. While the soldering process itself was quick and neat, the desoldering proved to be quite a challenge. I spent an hour and a half trying to desolder a jump wire at 400°C, but I was unsuccessful. The solder just wouldn't adhere to the desoldering braid, and even when it did, it would immediately get stuck, preventing me from heating it enough to return to a liquid state.
Could my struggles with desoldering be due to using a 45-watt power supply? Would switching to a 65-watt supply make a difference?
(11-08-2024, 12:32 AM)saranelson Wrote: Hello,
using flux?
soldering is all about flux, either paste or solid flux.
  pinecil v2 dosent negotiate power moses 0 1,671 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,106 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,541 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,766 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,462 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,879 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,397 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,251 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,180 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,188 05-15-2025, 10:41 AM
Last Post: dreieck
