Pinecil is working with 5v but nothing else!!
Exclamation
My Pinecil has finally arrived and is turning on when powered with 5v via the USB-C on my laptop but when connected to QC there is nothing displayed. I've gone through both troubleshooting pages for this issue. I've reflashed it twice and it doesn't heat when I press the + button. I'm not quite sure what to do with it yet but I did buy the breakout board so more is possible but it has been years since I've experimented with this stuff(LED does display on the breakout board when connected to QC and I've tried 2 different bricks so far) ASUS ROG 65W HDMI CHARGER DOCK - Best Buy (along with the included wire and an Anker wire) and the OE one for the ASUS ROG Ally(with the unremovable wire)..I've flashed with 2.23e.dd4a5500 and 2.22e.c308fe8c with no luck still and I did find the pd debug function while trying to flash and that doesn't do anything with it either!!  I haven't gotten my 5525 ports yet so I can't try it with that... any help is greatly appreciated!!!
It is in fact a compatibility issue!! i shall post an issue on the ironOS github! it works with a 45w laptop charger so i know it works!!
  pinecil v2 dosent negotiate power moses 0 1,671 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,106 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,541 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,766 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,462 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,879 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,397 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,251 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,180 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,188 05-15-2025, 10:41 AM
Last Post: dreieck
