pinecil v2 reverse polarity issue
Hello everyone.
I'm looking for a little help repairing my pinecil v2.Unfotunately I made the mistake of pluging a wrong polarity adaptor in my pinecil causing it to blow.
I replaced the mosfet.(U13 on schematic),the buck converter (U8) and the LDO regulator (U5) still not working.
After doing a little probing I found there was 19v input at pins 2,4,7 and 8 but no 5v at pins 5 and 6.?
Moving on to the buck converter (U8) I have 19v in at  pin 5. but I seem to have pin 6 shorted to ground at  pin2. Looking at the schematic pin 6 goes  through the inductor to LDO(U5) which i presume is not pulled to ground. This is a new replacement buck converter but i don't believe pins 2 and 6 should be connected together.Is this a faulty chip or am I wrong ?
 Any help would be greatly appreciated.
  pinecil v2 dosent negotiate power moses 0 1,805 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,166 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,633 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,902 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,544 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,954 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,518 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,328 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,256 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,402 05-15-2025, 10:41 AM
Last Post: dreieck
