Yubikey 5C on manjaro
tried using the yubikey 5C on my pbp but cant get it to recognize the device.
I was looking at this wiki https://wiki.archlinux.org/title/YubiKey and installed yibikey-manager and yubioath-desktop.
After that enabled pscd.service and tried to see if yubi authenticator sees the device but was not the case.
lsusb output did not show the key either.
Any ideas on what I could do to make this work ? Already trying two days but no luck so far
I have now tried the key with a USB-C to USB-A adapter and now it works without any problem. Seems like usb-c port issue ?
Can you try rotating the key 180 degrees before plugging it in?
Yes the USB-C port has an issue of not recognizing devices sometimes. It's not rotation proof, even though it should be.
thanks for your answer!
tried that already since I read in a forum about rotating the key, but it didn't make a difference.
I think maybe the port on my pbp is not working correctly since I plugged in a usbc-dock and could not use it, when I plugged it in the usb-a
port with the adapter it worked without any problem. I notices that I can charge the pbp through the usb-c port though.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,849 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,305 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,810 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,269 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,644 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,921 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,174 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,371 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,706 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,269 11-14-2023, 10:57 AM
Last Post: trifleneurotic
