Emacs on Manjaro Kde
I compiled emacs from git yesterday on manjaro, adding —with-x-toolkit=lucid to configure
and the toolbar works fine. I think, it is a problem with gtk
(08-08-2020, 10:46 AM)ennoausberlin Wrote: I compiled emacs from git yesterday on manjaro, adding —with-x-toolkit=lucid to configure
Ok, I didn't use that parameter. I am aware of other KDE distributions such as Kubuntu and Opensuse which have emacs working without any issues on plasma; if there is any gtk problems, they are aware.
I suspect Manjaro KDE is using some dated libraries but who knows. I am on Debian testing Gnome now. Installed emacs and other software that I have trouble in finding Manjaro repositories. Hopefully I will settle down there without a problem.
PS: If you are interested in hearing the outcome; I can compile emacs with the x-toolkit=lucid option on Manjaro KDE and see if it makes a difference.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,694 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,407 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,507 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,200 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,744 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,080 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,404 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,635 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,554 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,434 11-14-2023, 10:57 AM
Last Post: trifleneurotic
