Emacs on Manjaro Kde
Hi there,
New Pinebook Pro user here; very excited to use this as my productivity laptop.
I am having problems in setting up software to math my workflow. Emacs is one important program for me; I have installed it from the repositories. However, launching emacs is giving me troubles. First, it refused to launch, I made a workaround by adjusting the gtk theme. However, emacs is refusing to display icons in its toolbar.
I was wondering if there is any way to display icons and make emacs work normally? If so, any help would be appreciated.
Hello
I am on Manjaro 20.07 xfce and my emacs works as expected. Can you make a screenshot to clarify your problem?
On my machine emacs 26.3 is running from the pacman repos. Emacs 27 from guix is running, too.
A few weeks ago I compiled the latest emacs by myself on another PBP and this one was also working. Compilation takes a while though Smile
Tested with Vanilla, spacemacs and doom emacs.
So, chances are good, that you get your emacs up and running on your PBP as you wish.
See you
Enno
Hello again
Maybe you forgot turn on toolbar-mode manually.
It is disabled by default and I never used it
Alt-x toolbar-mode
hth
Enno
(08-05-2020, 11:17 PM)ennoausberlin Wrote: Hello
See you
Enno
Hi there,
Below is a screenshot of my emacs (vanilla except for a few adjustments on font size)
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAA0IAAABcCAIAAADMCJJVAAAACXBIWXMAAA7EAAAOxAGVKw4bAAAgAElEQVR4nO3dd3wURfsA8Gf2Wirpl0oIJCEhhBRCqIEQIvh7VdBXRaoUQVRApbyiKCCKVFEpojQJShEp0qVJSUiA5FJJCC2BkHK51MvdpVzd/f2RdoHc5Y6Ecvp8P/fJJ7e3t/Ps7Ozu3MzOLukR3AcQQgghhJCJ4DjVcnkcQhHqWUeCEEIIIYSMQGtowqYYYLAahxBCCCFkSgib0BoNAGA1DiGEEELIpKiAAEUIdqoihBBCCJkUQkCjpmkaO1URQgghhEyKWs0AQwiNnaoIIYQQQiaFxSEANLCwUxUhhBBCyKTQGobFoRgGO1URQgghhEwKRQgNQCjCftaRIIQQQgghIzDAgIYBprVr49wnx2SnC1q84hcNACp87sGL371kBwAA0SsSsneOc+yIUHQk16qwpbGCw+96AQC0jKcdzLtFTVm+Ze+5C7HpiecvHt3xw4ev9LQhj7u0joqqXbSyNCkz8VLcsZ2bFo7t7WBgyyvVOXru9sNnkpPir/31ZbQlgFXg5FU7z8fGp185s3ea35MNvZn3x0cEDxeM+tdPr1m0Y7kdVXTdJ8dkp66Ifmhq12nH0uOWDXp6YSCEEPoXIixCEw0NjI7WODpty5xdGU1v1aJbwDiXFeRTYsWTCKeV5NrEyLTj4Y/9fafz8pfWZxmXsGX4hz//NM2r5NKh3etuCGtZdl5hI8cs2jui3yfvLj4rMmABD6fbMqpniE758YMdaUBxrWzc/IaOnzR/Z4jla2N+udfmF23+s2jlWNczK2YtuQfm8ts10Gvu8k8HiTYtnnm5yoKU5T6F2AEAoPjYN/My6utr3d/8brbPhRWrTtZvkco7zz57EUIIoWeHYRiKzQIV6OpULc+Ku3yp5STx7rmTn1Q8rSTXFuZWczyEHz20F7lpbKpmYe+vnOaXv23KhE035Q3Tzhw4kvj9vlXLFl5L/vhkZRsLeDRd7aiercrbiUlX6/89f+aq0uOv2YMHu/xyr826qVd3f27RwV1HE+/Uv7cc4efGCH7efOm65kmG+4ja+8mX79f/q4hQg3te6uVLOU81AoQQQuj5RGsYQoAx6pmquruBKOcB73y/+9i1xPjEUzFrJofadlicFj1HL9p94ny6IC5u/7fv9rZQqR6Nxzxi/u/HPwmjXCfuTxdkpwt+fJlr2MK5Q0aPcpOc/TGmqQ4HAMCUn1+/96Zl5OiRLg2pxH/e1/2FeTuPn08VXI47+P2coa4sANCRbstcolwGTlv725GriVdSLh3evWLKAMfmDI9ekRD76QDvl+ZvO3wmNTE27ujWr9/wt2r81LrXm19v2R8bn5CecObcHxuXjvRmPV4WAgCATFYDTE11DQBYj9kiyF73H62l9fjklODMxz0ALAbM/OnkxjFO0PmD/YLs9MQ1k19es3v/Z/2BDFuWmS7I3j/NE0DP5o5ekXDhf0Fm/m9+t+90quDi1xFUh69II30Z29anzZ5MbC3iNGTX0F3GEEIIoVZQLEJrGIrobI0zgkXfebs2jao+vGHBD/dYfq9+MnfTFtaEcTvu00Ysg8WzsGi64IlRy+uUNAA4v7Yy5ovQBwc2zD33AFzCxi1b3MsSHmlOUqT9Ovczsy2bIhNnTdlxB6BOrHp4ltb59Qmz0Agux9U+/EFeXPyDj6b3C7f49XgtANhHf7U1MH7fxkVb6mzD3pr9/vc/caeNXZPWdrqdIhbu2fCf6r82L9t6p9q6+8vT39v2m/uM0cuv1DTM4PTi0s39kvZt++aXCpbvyJnzF6+pyXljdYYKeIMX//y/gEtrl8y+JeXZewX0c5NVGNkYRtg8Lg+A4nVy9omYNbFX4Z8Lzsr0f0WeuX/ZjHvvHVrV69B7s/cWQG1NDe9cTt7q3R+IV//fqgRQyURtbW77HuPWRnatPb55UYwkP5vuiBVphf6MbTPbG3RAbGxza2tr7QkWXO0Ko+G7hq4yZlw4CCGE/h0YhiEEaLWua+N01Kta4zR61luuWetfXHZQCAAp6VKP3rsmjQ/fuTzR8HocNWztlWFN75R/fRLy+SUA77FTBpqnrJ25/GAZAIAgvtT+0ub/PvJluqa8uKxaA5rqMmFxkcFpAnFwdIAykaiVM3exqBiIk5MDQC0AgG3R3vHL95QAAFy9Umz717axE4duTDvTVrruY2e96pS2dtyi/aUAAElxghr+qc/nvPXrlZjChlnsSvZOWlz/7lpynd/gHwf094CM++Ds7WtVnXziSGy6GgDSEuMMX60G1As/JL7Q+Eaa9ttnb69LaKMWB3R1eXF1eS0NallpcZEQAAAklEQJUCcuEhYDQJubmxsWLJ711uKE6oZFerZ7RVqhP2MNyPZ6HZDJUWsuRz0ytS6t4R9jdg0dZazO6JgQQgj98xGGMGogtK5OVWrY2iuxyY2v+MW6h97xwvoGkVuX4oQN7+n0tEyNbUAvd2PCoQXrpr47sfE1dUsqAIBlQKAX3IiLK2ucS5WUlGxME1/bGB3TCSEADNP4cWGqoKTxI036pQSpWc8e3m0u3CK0jz+5EXu5tGlK+cW/r0Ngn7DmgZaFiVeaqhaawvxicHRwBAAoiD2WwRm9eueq6cN7OjxWiymd9N2kd8ZNemfiu3PnrjhcN2L1kR1Te/IeZ0kttLm5hWf2NdXhoCNW5FH6M9aQbO+o2OjkDdPfn6L9WnysuUJv1K7xeGUMIYTQvxLD0IRNgKVzpKpg3bStyU3vKnQPcOxka0cgYPbBzNlNkwgLRC27mtpUlZuWnvrQNCsra4CKSrFWVGKxDDyNWrAeTHlpOTi5uLDgkYv3XZxdgMkrq2h4K5FKtGOVSOtja4OllRWBSrFW/CCprKTBzcamoZUPQFylvXoMDRRFAACY+zHvjr0zetL0CUsOzJibfHzHt+sPZkqNWj1J3vXMhsG/gvjzt1infpsxa8ShmccfrboSYvj9Vdrc3KWlJdrzd8CKPEJ/xhqS7R0Wm/huckqS9oSuIc3tZ0btGo9XxhBCCP07EYpW0xRh6WqEaK1e1SqpRAKQteP9Rae1T4CqyoJ2h1hdUw1ga2MD0DgCgVhbt+eOYQ+7JUipnTRo8BDzsxdb9l11HTrYi8naJ2icamdrB9BYO6HcXPkgk7XVQQkgqRIz4GhvD9DYHAN2Dg4USKTNOUXTOpsXlcUJe1Yn/P5T9+gJCz9dEMOXD//whFjXzG1R3829D+zOHnwA0SP1OFs7G4MX9Bibu0NXBKCtjDUk259cbNqMyqvHK2MIIYT+lQgAYVGgbv/DuBSpSZlMVz/3ipzcu82v/Ir2X5xdczMrH3oOHNB0K11Wr5AQTuvzKpUqMDMzMy4BdfyBo0U2wz+Y3F27s5E4RH80zl96cf+JpmYlj/D+bo3/s4P6hnDlWTdy2kxXmXw1jQ6IinRpmuIY9UIQ3ExNq2l1/lbRsjvnNi/bn2Ph59eeZkheUKAfMKKSMoCa8nIFODo6NX5EuvcKNjd4QY+9uTtoRQDaytjHyPYOjE2bUXmlu4whhBBCDyEEQM0Ao3OIg+FKDmz4Y8yWBb99677zbFZxHceG7xXiIdyxwaC75zZyDBwyuLlnUy3KuHJXDHcP7BK8/cXHmxbA1osFtFPI6HeiOTpOxQU5uXK7YdOnxqtTlIw4I6NAaUiqirQtn20P3vz+tgO+hw5eyhbWsuy7ho0cMyqo5sS8laebW2VqPKes+1Kz7czNKsveEz4ey8+P2RUnbzvd8oMb9ozbPnvrN6xNJ2/KrLq/8t7MPhUnZx140HZknUcumcrPvnIjVyghTkETXu4mTd1u5EndzrdPmAyAcK2duoaNmfpfx9KTi85KACDjWlLty6PnjUz+Nk7Ecw97e9EbbiooaXN5DYzc3B2wIo/Sn7EGZ/sTiU2bMXmlu4whhBBCD1GraTYPGOiIG45UC74fP71o7nuvf7R0kg0lrxTlCo5tfeQmHnpRoe9tCNVa4tFpEd9cBSg68Ok7nHmfTvx43WiW5P61X5fNuDzz2LjWFlB3fsPCP5Z8PHFlzHTZ6a/GGViNA6hJ+fH9Mdljp40ZMWneG44WmipRXtrxb8b/evKG9pVKWb8s+LvLR3NWzOdzpA8E2+d8u/G60pB05ekb355RNn/W6CU/uFiqym9f3T3zh+1x2kvWRVZSYffmu59P5Ftz5JWFmXHfTl9/wYg2PACg+ny0vQ8AAK0Qiwpvx62funl/UjUAQMWJlXPc/zdn5sYzS3i1hdfPxMz/dsQvkwxesHGbu/0r0hr9GWtotj+Z2LQZkVe6yxhCCCH0EIpFGGAoipAewX2edTDPtegVCRtdNw6euq+i7XkRehxYxhBCCBmF2Ei5ZlyGgXZfG/dvYMxQToQeB5YxhBBCBmM0AAywKKqDbuWFEEIIIYSeCsICwiPAtH+kKkIIIYQQeooIhyIUYWjAa+MQQgghhEyKrZRrwWGzWNgahxBCCCFkUjRACKE12KmKEEIIIWRSCJswhCEUjlRFCCGEEDIpDMUQNmFIR9z+FyGEEEIIPT0aYFRAMQRb4xBCCCGETArNsCgKr41DCCGEEDIxhEVommZx8Pa/CCGEEEKmhmEYGmisxiGEEEIImRQaQAMMwU5VhNBjCe8T9qxDeBwmGjaqh5sPoXoMAcIiFAuHOCCEEEIImRRC6v9iNQ4hhBBCyLQwhAKiUdJYjUMIIYQQMiUMMDTDsNgUVuMQQgghhEwJYRMgDIMP40IIIYQQMjFqAAZoNXaqIoQQQgiZFhbQADhSFSGEEELIxDAMQxEA7FRFCCGEEDItFBBGXT9eFSGEEEIImQ5azbBYFKPGpzgghBBCCJkWCmiggY2dqgghhBBCpoUBisUCDbD1z+Y+Oebc3IDcHe+8vuGGqnmy9ZgtF+YJP+r31dUOD8x9csy5uYEtJlUfnRaxQj13/xqPHa/P/0sMEL0iYaPbj0Om/F7eMWmad4saM23siL6+7k6WarHoQfrff27/7eQNCdMxi2+vZx+e9kbR1FWVie6nXjq1Z/fRtAq6cRYqXGsD/YNQ9r1envz2q9FBXm72PEVVWcGtxKM7tuxJr+roQmg8Yubo1a2rq30nHotWKeS10vLCvJzS2uek1AKAre+gcL4oMSFXqj3VqltEP9eylITbVY+zyIDIUJsHiVfzajsoRl0Ix8ali6crv5OFOZfSqBR1MnFx3v18iartr5pMim0w7xIW4dMJAAAYWq2qlYlF+ffyyuXPTwFrHds18p2ZM0b27+FioZKUCe9nXd6/ff25PM2TT/nZHxPQvwmhCK3WsDisNqpxAABAeU/+YtqptzfffQo7AgAA0Glb5uzKaHqrFt0CxrmsIJ8SKzo+McvwD3/+aZpXyaVDu9fdENay7LzCRo5ZtHdEv0/eXXxW1PHpmWp4dMqPH+xIA4pjYds5oP/I1z/dNWr4mllzfrulBAAARtbhG4g/9vedzstfWp/Vgcs0Dtv7jdXbv4jg3jzze8yfdyppW9duwREhTlT1M4uoGcvBLzTUhS7Nv3+jRklxLCxt7M25zPN+ijUNxNI9MMzfgUhLCx8IZSqGw7O0dbDlEnXbX+V59O3Du/VQzfWJpvhEMVW5aXlVFItrZmnv6uEd3NsiI+lG+eNG9ZiZYxSzQZ9t/Wmk6u9fNy++K+Hae/iEDPR0UD+tUxdCTw+jZgiXolWMAdW425fOWUW+t3jcX5N35z+ls0R5VtzlSy0niXfPnfwEUjILe3/lNL/8bVMmbLopb5h25sCRxO/3rVq28Fryxycrn0Ciphle5e3EpIbW14un9+45+fn2DZ+smZnxxroMFQAwtzp4AxF+9NBe5GZHLtJILN/JaxcOVp/6bMziC6WNzY77f3uGEWkhdm6uZrUFKdfvSRt2ysIHzzaifwxi1SXIz5EWZQmyyxSNR7yifIO+y+M7dQKjayntSfHJIspqsbgSAKBcVCym+4d5dObfLhc+Xj3u8TLHOFTf10a5FP4+de5PWQ277B87n2yKCD0jLB7FUAzFMuRhXKw721aekAXN+PJNVx1zUM4D3vl+97FrifGJp2LWTA61BQCweG3D1RvbR9s1LiXy6/PZ6Sc/CWr8ks+Mk+nnl/Y39OK86BUJ2TvHORqauoG4Q0aPcpOc/TGmqZIEAMCUn1+/96Zl5OiRLg1Jx3/e1/2FeTuPn08VXI47+P2coa4sAwKIXpEQ++kA75fmbzt8JjUxNu7o1q/f8Lf6R4THVAnWrDpc6fnfCRG8pqU1baDoFQkX/hdk5v/md/tOpwoufh1B6d1MlPPAKWti/ky4mpAae/zwz9N788wj5v9+/JMwynXi/nRBdrrgx5e59XO6DJy29rcjVxOvpFw6vHvFlAGOzeXnkUQ93t2blLb+ZWutsAM/PpwdvyyKZ8gqUgPGj/OTn1+9vLkOp2dmPYFZ93rz6y37Y+MT0hPOnPtj49KR3o1bpx1Fl2EYAEKg9R9WnE6du/cKHzAwKmrI0IjwYG8HHgCAebd+UcMC+VplA2x9BwyP9HcgAEDM7LsEhQ+IioqMGhQW2MWGY3gw7cDvGTmku4Oli2/vAYOGDR0SOaB3gLu11o9LVid3//CBEdFRQyL79upqy9K03BZmDl69+vQfOjRy2JD+4T272HM7ICT7zh5WmrI7t5prVFrYHqFRw4OdSfMUa99BURE+1gAsR9++A31tiZlnv+io4dFRIS6GHtz0pgigdzX5PSOH+tuZ833DBg4eFjUksl8vHyczAgBg1jU8KjrYRfuXeief/sMjA5xY8DhoWZUUCI/XsPe0XsYAANg27gGhfYdERkZHDoroF9zDxZLozJyOLnUMTdNAgNGxy+re4+x6jfvk272HTyQmXr5yes/G2YOatnHrR7OHD1mNy1Gxurzyv5gj51ITL8Ue2fKVcQd8hIygUdMUIQxtyEhVLlcVv2H1edWAjxeMaq0aZdF33q5NU7xu/7Zg5kef7coPnL1pyztdKai9mphFevXu03D+DR4aQUkkjpGDfeu/5RDWu6sy5Wpa22dI/XSkbiC/PmEWGsHluEeutMmLi38AAf3CLerf2kd/tfUd8/MbF82at2J/sd/073+aH8ozJACnF5dunm57bds3Mz/6clum7ajFa2YFG36keq7DU6VeTqix6Bse0Oqn9j3Grf32Tc2FzYsWfb0/m9YThvWghXs3zQgWn123ZOH/Vv36d0quUKFI+3XuZ4eKofTIrJdGDX9p1JILKgDoFLFwz49TffMPLps/Z+7qQ0V+07b9tnCgpa5EC48cSWEPemlE86G6x39e9BD/feqyQV2//gMH2CiunL9kwFVY+gLjDV788/96l+1fMvu9qfOW/3Q6v0xWUd/F076iKy0rV5m7+fg4mrd2Uja3tlSV5d1OT824KVTZevUMcOUC1IlEMpaTs1Pzib2TC99MIRJVMsCy9+kT2sVClp+ZnpGVX2vTLaS3lwVpZckdj+fsH+rFqbx/Oz0j+76E4+of2M2mIRt4boFh/nyq8v71jMzsgmrbAH/tHyhsR7/w4C5WtUW3sq5fv1NUZ92ld7i/w+PVUZpZOzhw6MrSMqP74eiq/OtZQjkoitMTrsYnXL1RZuDBrY0U21xNjlNAqBdVlnMjPfN2odzaq1eIry0FIBcKxcTBxbl5h7Z2djZXlorKH7OL0cLSEpi6usa9p9UyBsBy7BHia6soyk5PS8m8fU9Uq9QoGR2Z0/Gljrl+IU7i8fq8OUPczR5dAT17HO0e4FN1YcfqWdNnLz1S1Xv6qq9G2Td98aGjWWuHrMZZfd5eOdkq9ucl781avCXDZtTiNbNCns4PIvSvQxFCMzShiAGdqmw2G6pOrtn4+uEvFix4IXbB35IWHzuNnvWWa9b6F5cdFAJASrrUo/euSePDdy5PTBTc573RtxecSwEIHDzUNnP/Lsd3IwZ5bLpbCNy+fXox6T8ktn5CZfEsLCwa3zBqeZ1S1wFRd+qGHEKJg6MDlIlErRzWikXFQJycHABqAQBsi/aOX76nBADg6pVi27+2jZ04dGPambo2A7Ar2TtpcUwhAMC15Dq/wT8O6O8BGfcNCO65D48uEZWCg5MDBfBoZnPDgsWz3lqcUH8ZmdNknWG4vjXzVX7mhhfn7RYCAMCF+u+XF5dVa0BTXSYsLmpYpPvYWa86pa0dt2h/KQBAUpyghn/q8zlv/XqlfgUeThTg1LH4+UtH/Z/ToX1lAECCRvzHrfLUiUSDuoQI39kJSgqLDJhZb2DO3r5W1cknjsSmqwEgLTGu8VvtK7qgKrl1PScg0Du4v4esTFhUlF8sltPNH2anlTT8L7lj5dzP084aiitqRaIqb28XR7ZIpAYAYuvMN5OLRFUMcD26eZhJc+JvFckBQFylMrcN9/S0zbv1NAascBUFydkP6gAAKqtoa6dgB3szkNQCWHbuYs8S302/VaQAABBXKLiDQ90av2beuZsbT3I3Kbuw/tPySg1vkJ+Px4OK+mU9JjMeF+S1dcZfP8KoFXKFmgFGpZDLjYlAf4oGrCanrlBwO18OAFBZoeAMDPXo7JRbVaIoKa7w7eHqzC0qVAIA2PBdzJQlIrExq0YoFptNsbhmVg6du3lZKYW5jVfG6ShjwLO0ZKvFImG5hAGAqsqGy/1by5wnUeqkZ5bPXbd85ewNf751J+7w/j92HUsW1V++q3+Pk5xe/N7phmVkrvV7cf+k3j3gaEJDoC0OLK7TWj1k1bMR7Z2wdKcQAECQpugRuWlAPw9IN+yIipAxGBoIoQx7pioBAgAlR5dtvm41Yv4nEZYAWldS88L6BpFbl+KEDe/p9LRMjW1AL3eAHMG1Cvs+YV0BwH/IYOespL0XBKX+g4Y4AkDP8DDuzcTE1gerUcPWXolNbnzFLx6kMzY9qRtI1yGNENLQcwUAAIWpgsZDFmjSLyVIzXr28DYkgMLEK4VNXyzMLwZHh9aaNE0yPBbFAqB19F8Iz+xrqk7pCYMXHNaT3Dh/XtjqQrRZhPbxJzdiL5c2TSm/+Pd1COwT1lTjb5EoAMgu/Hmhts8r/+cGAEBCXxzuIjp7PMXQtggCwOMZ0EunP7CC2GMZnNGrd66aPryng9avpvYXXZX0fsa1+JTbwjpzN/+QQf0D3VpvyFDI64DNYRMAUJQWi4mDsyMbAIDYufB5tSXFEgCWnZ0NyMoqmvruJRIpw7G2sWhteR2urrKiqdbD1NXWAZfLAwBgdepkAdKK8qbfenSluKppj2DZ2lmDtKz5U1CWlUmhk51t+9rjGALAYj3NOzHpTdGQ1ayrqmzackxVeYWKZWNtCQDqsqIyjZ2rS327lC3f2UxeWmxULQ6ceg0dHDVk4KC+Qb526qKstFutj2/QKmO15SIJ5RHYJ7ArvxNXb8vaEyp1ksyts18fMW3ln/nu//3851OHVr7mxQYwao8TCYVgadOpOYdbHM30HrIKk642faApLCgGJ0djDvgIGY4ChqEpFmXISNV6TN6eVb+M3PX+57OPvL6RbjoVdrK1IxAw+2Dm7KY5CQtE1tYAkHktqW5sWG8bUEcN6XL774SSTOcE2djIiE57M8LC7UWXrhW0nhQtWDdta3LTu4p7OoPSl7oh61ReWg5OLi4suP7wud3F2QWYvLKKhrcSqXYbZJVEClZW1oYEIK7S+mVJMzRQlMGdBs95eGx3T2couVTa+qelpU0VS31hyG1tASoqDfj5bWllRaBSrD2npLKSBjcbm4Y2yZaJAgAoLh45K97y0iteu7bmB780wjn/xF8ZBp7FmIqyCnByd+NARhu3fNAfGHM/5t2xd0ZPmj5hyYEZc5OP7/h2/cFMabuLbgNaXiW8UyW8Z+kaEOIfENC5MjlfDkDM7Lp0cXe0tTRjs1kUUGyAhrEwyhJRpV8PPp8jEqpsnZ24ssISGQCwORyATt36veDdtPpAQM42/PDQOgbII8WJALT4IQigUmnlMNP8JQ6LDaBUame/UtW0J7BZLACl9ldBpVQwYM7hALRjZKJKoQSuuRkFEgP7RB9dxY5M0ZDVVKm161ZKtRpY9ZuOLhOWKns7u1rk36+zdXHm1YpELftS2iTOSckT02qVUlEnV2mHp7uM1eSlJsncPbt6+vfz8hUX593JLZK2ugs9qVIHAEpRypG1KUd+9h61fNOiZV/fSJq0W6h3j2O59J009c2hId3cbC15bMrMGuCK1vJaHs30HbKqtI+oDMPU/+JG6MkgBEhb941rQXN36zf7Xtk5bukHZ2KUjROlEglA1o73F53WHoKkqiwAAHViUjqzIDjEhR3RveDiovtAF8VeUawa1NeF07ubNGmlzmGIVblp6amGhKQvdUPcEqTUTho0eIj52Yste0G6Dh3sxWTtEzROtbO1A2jckyk3Vz7IZDJDAqDpdlz991yHZzE4ehCv5m/BrbZn1RMGkckA7O3sAIrbWIikSsyAo709QNOvXTsHBwokUj2D39RJx44Xv/7K/3lvS4oe4ZT3xwnDh77eSk6pfXtI9HCbU3/pP/W1GZiyOGHP6oTff+oePWHhpwti+PLhH54Qt7fotqCuKb4n7Ozc1dqGgJyy7R4W4qYsup3zQFKnVGtYrj37+TYlUCaq8A9wceIU1/H5XFmeqAYAQK1SA0gfpN4o0a4P0Mr2dE7WV8+4PHMCUq1KG+GZ8UCpUmrNx+i4T4pKowbgcNhatTJOc6OVSqUC4LWos3E5PPJQncZ4MrFY7enI53NKRK1VPpiHT8ocTnurHXpTNGQ1OWwOQGObFjE349VvUABgxMXFcjcXZ8v7YidnXm1hsczI2FQ1VVWt9Jmw9JUxoOUVBXcqCu9Z8Tv7+3bvw9PEZ4iUjy7kyZQ6bTW5xzYdmTBiRmAgBUI9exyv92c7Nr5W+efK9THpBRWyOt4rq/78RNdCZXoPWe064CNkBIZmGA0DYOTDuBQZW5cdKe82ccE4t8ZjiiI1KZPp6udekZN7t/mVX6EAAJAmJt00D06vNOIAAAoXSURBVOw7OrSX6PLFOwCgTLicxO7bb2pooEqQlNr+8q43dQOo4w8cLbIZ/sHk7tqDF4lD9Efj/KUX959o+gnmEd6/6ZocdlDfEK4860ZOBwRgquGxXV/4+tMXLXJ+/y3BgNuT6glDfj39DvSMinR+5EtKpQrMzJqvU1YmX02jA6IiXZqmOEa9EAQ3U9Nq9CTN3PjzaK7PsKhRUUMdb586lmv4KqouHzpRbBn54ex+NvpnNDAwWnbn3OZl+3Ms/Pw8ocM3DcXlcUCtUjIAlg58M1Vxzh1hhaymVqFQUBzt0qMuLy6j7fmOTnxHTpVIVH/K1FRVSsDCylxRXVPd/KpTtu92WzWVYgWxd3fVTp7r6u5IybV6UfXQyKS10Mneoaljm3SysW06YtHiiirGmu/YXEK4TnwbkEmq2leNoyuEIjnb0dvbvrVL09VKBQ1cXvMqWdtod+LSNAMslpG9unpTNGQ1Leztmz4mNnY2FC2VNpY9qVBYY+Xk5ObkyK0WCfXtKsbQX8bqMerqkvs3i6pZ1tbm9avyUOY8mVLXEtfR0RqkVWJa7x7nM2iYm+zoutV/Xrl5r6C0rNzC/tHjURPdhyyEniYWj6LMKYYyqjUOAKA2ft13Z4etHtEdZDfqp5Qc2PDHmC0LfvvWfefZrOI6jg3fK8RDuGPDWREACAXXCj96/Q0b8ZkF9TdxrYmPT1n24asRZmk/CuS6kzGY3tQNoEjb8tn24M3vbzvge+jgpWxhLcu+a9jIMaOCak7MW3m6uXm8xnPKui81287crLLsPeHjsfz8mF1x8o4IwHTCs/fr17eWsM1s+D7BEa++OsRTGrtk/vbbBtXF9YRR8MeWM+O/+3DHGqvtZ29L2A4+oeYpq39PoaEgJ1duN2z61Hh1ipIRZ2QUlB/csGfc9tlbv2FtOnlTZtX9lfdm9qk4OetAG/dLu3v0eNaMcR/b8NN3nzKqqUue/PPCmKCfpq470u3kgbOp9yo15jZOnv5OOTt+ONniuhi9gXUeuWQqP/vKjVyhhDgFTXi5mzR1e04beWIAq86hvlbVYlltnVJN2Ba2Ll3c2dJ7wioAUNTVMmwbBzszqUTNsXT09HHnMdA83pYuE5VpAj19LDmVeaWNlUZFUW6hR+/u4YHmD8qkcg3F4VrYmtfl5Za2ayeV5t8pde7l3yfMurCkqk7NMrPhu3e2VxdnFhh297Dqonyxp793cHcmr6yO4dm6d3GimisvyqKcgs5h3qEB1D2RVM2xcvHqZqcQpRe29wEPGvH9Gw9sQroE9bcQFZVW1SgZFodnYc2tzssRyUFSUalxcfdxEd+tUFDmNp7+bmY0NNW966praI6TV5cKpopmVBJJrUG7h94UDVhNtXmXoB5MXolMxbbt7O1hVvcgq6KpLlRdXCzt1tmbw6sqKOmwdi49ZczctYcXT1ohrZGrgGvT2cVSXZVX03rmPIFS5zvx5/neOYLbD4RlUrD2Chs56Q2brE2HUgH07XElhflqq5DB4c43Mmo6eQ+ZMu+/DhrQ+ZNP5yELoadJrdBwzTgMY3Q1DkByYeUPVyKWDmyaUC34fvz0ornvvf7R0kk2lLxSlCs4trXxGHPnWpJk2uvUgUvpDf0mkoTYrC/6Bd29eq1j7lyrN3VD1KT8+P6Y7LHTxoyYNO8NRwtNlSgv7fg34389eUO7Ky3rlwV/d/lozor5fI70gWD7nG83Xld2UAAmEh4VNntLGACtrJWW5N0U/PrFvN//viMz9HJpPWFUnv9q/LyiT6aP+nS5I1chzru+p354WN35DQv/WPLxxJUx02WnvxqXUaCUp298e0bZ/Fmjl/zgYqkqv31198wftse1ebFP8V+HBLO/DE/fdqqtfttHok5aP+OtrPHTxw5/44MRTp24allpbua59EcazPQFJiupsHvz3c8n8q058srCzLhvp6+/UNNWnrRNWSvTOPHd7XlcDqVR1tVKCrPu5JVUMwCgEN68YdmjW89BnVm0qqYsPyf1vnc/rVvS0RUikcbFg1uZV9rc06UW3xWk1Pl0dffx92QTWqmoEQvvt/sZAkpRVoq6S7eurh7d3TigUdXJKu6m3csXt9LD1qq6oqwUyqe7p0+QO1HVVj64lVbuPcCzaUUkucmpCt9uHv7BXdm0srqyIP1uXnkHPLxKXZmTlijt7OXBd+/G57EpRq2olpZW0fWrdPu6eXdv7+BBPSi6Tip6kHmXH9YUkqYsJ6vQ38ezZ5iXWnQzycBqnP4U215N6YOsUnNvn56+PKKurcrLuJOrfZWdvKSo0ruHXVWeqCN+ONfTU8bUcgXH3cuvsxmb0ijrJBV3U3LK6gvSo5nT8aWuIvdmbdSI0YP4dtYcRaUwL/Pg56t+OdXwACKde1z50a++8Ply5opT4y1UFTmxv697b8tHB0J1JqLrkIXQ00RRFK2iKRaL9Aju86yDed5Fr0jY6Lpx8NR9FW3P+ww85+E9B6z/u/H0V5y1Q94//DiP8UQ6hPcJEySnPOsojGaiYevC7xkZbJYbm1Kou2rMdgseFEDdjU0TPrPns3acf9jmQ+ixETsp14xLEfI0x9Wbsud8uNFzHt6z5fbKWwPV5/88h3U49M+kf+c3c/FwYEqLSv8BdTiEkDbCJoRtyO1/ETJJZm5+3o42XqPmvB+Qu3vp38/D8+wRempYZlaWPK6Fq09X65r8m6Xt7iFHCD1PGAaAAYYwWI1D/1SO/1m0dU732oL0o3O/2mHYUAyE/jG4Lv6hPtaaOonoevYDY280ghB6zhFCNBoNm8Jr4xBCj8VEr1Iy0bBRPdx8CNWjHGRcLocBwGvjEEIIIYRMCdEQWk0TGoc4IIQQQgiZFA1o2JZswsLWOIQQQgghk0IIUSs1QLAahxBCCCFkUhgNEABg8IYjCCGEEEImhRDC0EAzeMMRhBBCCCHTwgagABgGbziCEEIIIWRKKAcZx4xNGAqvjUMIIYQQMiWMGgCAYXCIA0IIIYSQaSEMECAE2DzSyrP2qqvxAZQIIYQQQh3Jysqq1enG1rt4jiyGBorC2/8ihBBCCJkURsUQAEbDYDUOIYQQQsiUUFyKZhhC4bVxCCGEEEImRaPWUBQBGqtxCCGEEEImhRBCqxgg+BQHhBBCCKHnCcfStn/f8KBegRmZWYlJAgBQ1VS1mIMiFI+iGRpb4xBCCCGEni8hIUEcDjs0JKjVT+vHN7AovP0vQgghhNBzhkVRTX8fRWtoQhEaR6oihBBCCJkYigAA4FMcEEIIIYRMjAaAIQBYjUMIIYQQMi00AxqaMIAjVRFCCCGETAmhKGATALzhCEIIIYSQSSEEgAaaYbAahxBCCCFkShgWAMVQePtfhBBCCCETo2KAQxgc4oAQQgghZFooDsUQhrCwGocQQgghZFJoNQMM0Gq8/S9CCCGEkEkh9S8WwWocQgghhJAp0WhooCiGZv4fD405Uu/9TM4AAAAASUVORK5CYII=[/img]
Hello
I am not in front of my computer, but it seems to be a problem with the x-toolkit.
Usually I use xaw3d, when compiling emacs by myself. I don’t have kde installed, but you
could check the output of ldd emacs to see what toolkit is linked. gtk themes sometimes have
icon problems. Maybe its related to your problem
(08-06-2020, 09:33 AM)ennoausberlin Wrote: Hello
I am not messaging from my new pinebook pro right now. I just wanted to give you more details about the problem:
After deciding to use the default Manjaro KDE in the flash drive; I installed emacs from the pacman. Trying to launch the program didn't work for me; after a bit of googling I figured out emacs doesn't like inconsistencies in theme settings between the kde look and feel and that of gtk/gnome. I set the gtk settings to breeze and I am able to start emacs now.
However, the toolbar of emacs is lacking any icons: neither breeze nor adwaita icons. Fortunately, all the toolbar icons are still there with text only. So, it is still usable. I am not sure at this stage if this is intentionally tweaked by Manjaro/Pine developers. In any case I am not happy with this because I tend to use emacs toolbar at the side of the emacs buffer to gain screen estate. Text only icons occupy too much space esp. on the side.
I will try your suggestions and update if it fixes anything. If it doesn't fix, I will compile emacs from sources to see if it fixes anything. Emacs is a very important program for me and I want it to be working as bug free as possible. I may consider switching to Xfce or maybe debian (though mate desktop is not my favorite environment) if I feel further problems with Manjaro kde.
Thank you for the suggestions. I will keep you updated.
PS. Apologies for the screenshot mess; I couldn't see any attachments buttons on the forum post screen so I decided to copy and paste the image... It has been a while since I didn't hit a forum and given the amount of issues I need to solve with my pinebook, I may likely need to set up the forum in my email client perhaps. Ah ok, I just saw the "Add Attachments" button now. I will repost the screen shot if I can.
Hi there,
Attached is the screenshot of emacs menubar+toolbar.
.png   Screenshot_20200806_185625.png (Size: 20.42 KB / Downloads: 838)
Update: I tried issuing the following commands:
$ ldd /bin/emacs
the output of which is in the attachment as a text file.
.txt   ldd_output.txt (Size: 7.57 KB / Downloads: 687)
I also try to figure out if xaw3d is used by emacs by any means. Apparently not. I installed xaw3d from pacman to see if it changes anything. It didn't.
I will compile emacs to see if it makes any difference. Bottom line I will leave emacs as is for the time being and try to switch to either xfce or another gtk based environment.
Hello
If you compile it by yourself,
please ensure that all needed dev libraries
are installed first. At the end of configure emacs
will tell you mostly what he will use and what is
missing. It’s worth to dig into the options, especially
if you live inside emacs as I do Smile
BTW: Emacs 27 will be released soon. Better write down
your config in case you want to switch in the future
(08-07-2020, 04:28 AM)ennoausberlin Wrote: Hello
I compiled emacs from git sources today and tried running again. The problem persists. To ensure I have all the requirements, I installed base-devel metapackage and made sure all the required dependencies indicated in the wiki below are installed:
https://www.emacswiki.org/emacs/EmacsSna...ebian#toc3
I have little experience with this Manjaro thing; as far as I understand the .dev files are automatically included when I install a package. Thus, I think I don't have any dependencies missing.
During the configure phase, I only specied prefix to .local as I install it as a user. The result didn't change anything same tool bar without icons.
I remember similar issues a year ago when I was trying emacs on fedora kde. I thought it is fixed because I have emacs-snapshot on a kubuntu machine and it is well integrated; consequently, even better than my emacs experience in gnome.
I have little experience with Arch or Manjaro; I am coming from Debian, just a week ago switched to kubuntu due to a crash on update on Debian on my other pc.
Just to add to the above during the configure phase the only complaint (suggestion) emacs did was including gnu mailutils (not available on repos) and some info related to pop mail handling.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,397 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,011 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,097 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,992 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,505 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,860 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,082 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,245 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,369 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,204 11-14-2023, 10:57 AM
Last Post: trifleneurotic
