05-20-2019, 02:39 PM
(This post was last modified: 05-20-2019, 02:52 PM by phuzy.
Edit Reason: Wording / spelling
Thanks!
No instruction manual. Can provide if other members are interested as well.
I've made similar modifications to other devices before. Just went by my own experience.
Scoped out a good spot inside the pinebook with an unused threaded insert.
Cut out the necessary hole and edges from the plastic shell/panel to expose/accommodate the micro USB.
Probed the board for the 5V and GND connections to the barrel jack.
Soldered wires connecting the barrel jack connections to the micro USB breakout.
I didn't use a diode but it would help to prevent reverse voltage when both the barrel jack and micro USB are powered by different sources.
As for the OTG-USB. I found four closely situated pads near the WiFi chip on the motherboard but I'm not sure if those are the OTG-USB ones. I did not use the OTG-USB connections for this mod. If they are readily accessible, it may be the better option as opposed to connecting to the barrel jack.
