Pinebook's battery flat on arrival
(08-29-2017, 06:59 PM)MarkHaysHarris777 Wrote:
(08-29-2017, 05:17 PM)p3p1 Wrote: Finally it's working after 23 times. I have a question the right ways to shutdown are the shutdown dialog or press power button (physical button) for 12 sec: is there a way via terminal ?
There are several ways to shutdown and poweroff the system.  The two main (best) ways are following:
1)  press the power button (physical button) briefly which will pull up the dialogue, then click "shutdown"  ;  this will do the  "poweroff" under the covers.
2)  on a terminal enter :
       sudo poweroff
shutdown -h now   is deprecated;  since systemd don't use it !
sudo halt  will only shutdown the system;  but it won't poweroff !!
New problem: with pinebook turned on if I remove the power supply it turn off (as if the battery not present). If I re-plug again the power supply the power led blinks and power button doesn't turn on the laptop. In this case only solution to boot is unplug and re-plug the battery connector under the cover. How I can solve this?
Pinebook's battery flat on arrival - by Luke - 06-26-2017, 10:52 AM
RE: Pinebook's battery flat on arrival - by Erik - 06-26-2017, 01:29 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-28-2017, 03:46 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 04:53 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 05:17 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-30-2017, 04:20 PM
RE: Pinebook's battery flat on arrival - by dejan - 03-19-2018, 08:33 AM
RE: Pinebook's battery flat on arrival - by Luke - 03-19-2018, 09:04 AM
RE: Pinebook's battery flat on arrival - by tllim - 10-30-2019, 07:49 PM
  Dead Pinebook - fix it or spare parts? oloturia 2 2,336 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 1,020 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,395 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,199 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,042 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,677 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,736 08-18-2021, 11:01 PM
Last Post: Corkonian
  Battery life unrealb2 4 5,779 08-01-2021, 12:26 AM
Last Post: unrealb2
  new pinebook help ron_burgundy 5 7,932 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,905 12-07-2020, 04:02 PM
Last Post: SanjevR
