6/22 run of PBPs - is reimaging eMMC with new OS possible still?
#27
After multiple renamings of the UUID of armbian_root, I still don't understand what's going on.
Upon boot into the eMMC I reach the "Begin: Running /scripts/local-block ... done." loop.
I have renamed the UUID of the eMMC root partition to fit what was in fstab, but then get ALERT! UUID=the_uuid_of_the_armbian_root_partition_on_the_eMMC_card does not exist, which is not true.
I don't understand why this is so hard! I even have a RESUME=UUID=the_uuid_of_the_armbian_root_partition_on_the_eMMC_card in the initramfs-tools conf.d.
This just doesn't make sense - are pinebook pros unable to read UUIDs properly?
Can someone help? Btw WDT temp2fs is not usually in PATH you have to use /sbin/temp2fs.
Also WDT please be mindful that a lot of people don't even have a bootable system or are able to boot but not enter their root partition, so they might be in a busybox/initramfs shell instead of a full Linux shell
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by elitegamercody - 10-04-2022, 07:03 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,223 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 442 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,014 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,557 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,951 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 882 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,131 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,075 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,501 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,612 08-18-2022, 11:47 AM
Last Post: Bemo
