NVME SPI Update not booting SD Card
I updated the SPI following the instructions here https://github.com/pcm720/rockchip-u-boot/releases and now it boot directly to NVME but I seem to have lost the ability to boot from SD (green light won't come on at all).  If I remove the SD it powers and boots just fine.  BTW EMMC is removed at this time so that it won't boot first from that.
Was hoping to use the SD as a fallback to bypass the NVME if needed.
(08-16-2020, 08:39 PM)WZ9V Wrote: I updated the SPI following the instructions here https://github.com/pcm720/rockchip-u-boot/releases and now it boot directly to NVME but I seem to have lost the ability to boot from SD (green light won't come on at all).  If I remove the SD it powers and boots just fine.  BTW EMMC is removed at this time so that it won't boot first from that.
Found a newer update here https://github.com/pcm720/u-boot-build-scripts/releases
Trying that now.
Trying that now.  It worked and also returned the LEDs to work like it did from the factory Amber after power on Green when boot loader located.
It states in the wiki the factory 'boot  instructions' are on the eMMC.
That guides it to 'boot' from the sd card first, if one is inserted.
If you have flashed the SPI, that should have included perhaps boot sd card first and your NVME second ?
Then without an sd card it will boot first from your NVME.
@WZ9V Do you know how to configure the PBP to boot from NVMe without removing the eMMC?
It is in the compile options for that particular uboot, for example (pcm, dated Aug20)
@localhost pcm-uboot]$ strings u-boot.img |grep _target
boot_targets=mmc1 nvme0 usb0 mmc0 pxe dhcp
(mmc0=emmc,,mmc1=SD)
@WZ9V I have to wonder if that SD was bootable, if the nvme was disconnected or removed
would the same thing happen? (op, I know, old)
  New Working nVME gilwood 0 243 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,577 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,856 11-28-2022, 12:56 PM
Last Post: dachalife
  unable to boot after manjaro update gega 6 3,242 10-28-2022, 01:18 PM
  PBP booting but stops at flashing power led jonasd 13 5,561 09-26-2022, 12:17 AM
Last Post: jonasd
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 1,082 08-12-2022, 06:41 AM
Last Post: JessicaQ
  NVMe drives not detected mattpenn 12 10,532 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,946 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,882 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,909 12-10-2021, 07:47 PM
Last Post: josmo
