Modem won't register?
Several times now I have found that the modem loses registration, then won't register.  Once I solved it by flipping the modem switch on the back off and back on, then rebooting. Once I have solved it by merely rebooting.
Running mmcli -m any --3gpp-scan times out, whether the modem is registered or not. When not registered, running mmcli -m any --command='AT+CREG' returns ' '. Similar results trying to do it through modem-manager-gui.
This is on a PP beta edition, Mobian Bookworm/Phosh, haven't changed the modem firmware from what it shipped with.
Any ideas what might be causing this intermittent issue, and how to stop it?
Edited to add: Settings and modem-manager-gui agree that the modem isn't registered, but I still have data, can ping google.com. I am using a Pure Talk SIM.
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
(08-23-2021, 06:32 AM)nelstomlinson Wrote: Several times now I have found that the modem loses registration, then won't register.  Once I solved it by flipping the modem switch on the back off and back on, then rebooting. Once I have solved it by merely rebooting.
I'm not sure that you're describing the same problem that I had, but in case you are, give this a go:
In terminal, run
sudo systemctl stop eg25-manager
wait 10 seconds or so (the screen might start flickering; wait 'till it's done) then run
sudo systemctl start eg25-manager
Assuming you have the same problem as me, your modem should reconnect around 30 seconds after this. If this does the trick, try reading https://forum.pine64.org/showthread.php?tid=14099 and https://forum.pine64.org/showthread.php?tid=13885 to learn about the problem and a workaround.
  Modem crashes worsening from daily to multiple times a day + sms delaysFor people car bacydentir85 2 4,111 02-03-2025, 01:34 PM
  Modem white list aular 7 7,240 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 6,451 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 5,820 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 7,386 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 4,041 02-04-2023, 04:01 PM
Last Post: jack1
  Won't boot - Failed to read Who-Am-I register nocargo 6 10,508 04-30-2022, 06:11 PM
Last Post: TRS-80
  The modem switch affects the connection to battery? JohnDoe 2 5,345 03-30-2022, 12:02 AM
Last Post: JohnDoe
  Modem disabled, can't enable: Invalid transition pac 4 8,715 03-23-2022, 01:08 PM
Last Post: Firewave
Question Modem problems with the distros I tried UltraBlack_ 9 12,165 02-21-2022, 01:57 PM
Last Post: KNERD
