Modem crashes worsening from daily to multiple times a day + sms delaysFor people car
For people carrying the phone with them, is this something that you noticed?
Context
- pinephone used as an sms server through ssh
- modem and wifi experiencing multiple crashes that are worsening
- incoming sms are sometimes (but rarely) delayed from 2 hours up to more than 24 hours (received time and dates are correct)
Crashes in the past 45 days
- 80 for the modem
- 12 for the wifi card/wifi connection
- more than doubled since the last 15 days compared to previously
- modem and wifi checked every 30 minutes
Phone information
- pinephone beta edition ordered in 2021
- on 24/7 + plugged in
I have had this setup for the past 3 months, but I started logging the crashes in mid December as I started to see the pinephone going down more frequently.
Software
- sxmo + postmarketos edge
- not directly exposed to the web, it is only accessible through another server that runs a secure bsd OS
It seems to be worsening and I have not changed anything on my setup since I started logging the modem and wifi crashes.
I do not expect 99% uptime as it is targeted for testing and I have the beta edition, but these crashes seem rather high.
I don’t know where edge stands now, but postmarketOS 24.12 wasn’t looking very good on PinePhone overall:
https://gitlab.postmarketos.org/postmark...ote_459502
Also, I’ve long had modem problems more regularly when using sxmo. Don’t know why.
I have nearly no issues except some volume setting tweaks running Mobian, FWIW I also installed the Biktorgj firmware which made the modem much more stable.
This is the master source for Biktorgj's modem work.
https://themodemdistro.com/
It has documentation and fixes(especially for newer modems) and apparently adds hours to battery life on standby.
https://github.com/the-modem-distro/meta-qcom git which is good for looking at bug fixes.
  Are you using the Pinephone as your daily driver? jro 157 234,692 02-18-2024, 11:33 PM
Last Post: aular
  Modem white list aular 7 7,297 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 6,489 01-15-2024, 10:05 PM
Last Post: aular
  Multiple issues with the Pinephone MTXP 12 13,833 12-28-2023, 07:55 AM
Last Post: MTXP
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 5,853 07-16-2023, 11:14 AM
Last Post: kebab
  Is it normal for the pinephone to "discharge" after fully charged on multiple OS? Shad190 2 3,816 05-10-2023, 10:37 PM
Last Post: Shad190
  Modem gets disabled on every suspend jojuma 5 7,456 03-27-2023, 02:51 AM
Last Post: jojuma
  are you still using pinephone as a daily driver? zetabeta 29 34,679 02-09-2023, 11:48 AM
Last Post: silverwing
  Modem audio settings jack1 2 4,061 02-04-2023, 04:01 PM
Last Post: jack1
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 12,781 02-03-2023, 01:27 AM
Last Post: dante404
