Screen refresh delay with kernel errors
#31
I haven't noticed much of a speed improvement.. I gotta do some more tests
"That, according as it is written, He that glorieth, let him glory in the master."
1 Corinthians 1:31
(07-08-2020, 06:06 PM)shawnanastasio Wrote:
(07-07-2020, 10:20 PM)bchenlee609 Wrote: Thanks for your last reply! Life gets in the way tinkering with this laptop unfortunately.
May I ask for some clarification? Which .config file am i editing after the 'makepkg -o' step?
And once in there, how do I modify the LOCALVERSION string?
Sorry if these are silly questions, this is all new for me.
I wish there were a way to check at this point whether or not I applied your patch correctly (without modifying the kernel localversion string)
I'm assuming this is not possible?
Thanks again!
-B
Like I mentioned earlier, I'm unfortunately not too familiar with manjaro's packaging system so I'm not sure exactly where their kernel package would store the config. `find . -name ".config"` should be able to find it though.
That said, the patch has landed in manjaro ARM's linux-aarch64 repo, so you should be able to just update (and keep your APPEND) to use it: https://gitlab.manjaro.org/manjaro-arm/p...2f97945e6a.
I have the old first gen debian PBP. I installed Manjaro today.
From what I'm reading here, will pacman -Syyu install this patch now?
  Another one boots to black screen Sb2024 7 7,317 11-06-2024, 11:27 PM
Last Post: Sb2024
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 2,378 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 11,457 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 8,071 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,336 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 8,675 01-22-2023, 09:55 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 10,792 08-15-2022, 06:28 PM
Last Post: svmhdvn
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,620 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 5,508 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 6,457 05-09-2022, 05:53 AM
Last Post: gerstavros
