minimal kernel .config?
Hi!
I just received my PBP and will install Gentoo on it. My system is ready and I have compiled the kernel based on the Manjaro config.
But I would like the minimal working .config (just the needed hardware settings).
Do you have some one?
Kind regards,
Xavier.
Kind regards,
Xavier Miller.
make localmodconfig does the work
Kind regards,
Xavier Miller.
I posted one here, https://forum.pine64.org/showthread.php?...8#pid84938
It's not for the newest kernel, but it should be pretty close.
(06-27-2021, 12:59 AM)xyzzy Wrote: I posted one here, https://forum.pine64.org/showthread.php?...8#pid84938
Hi @xyzzy !
Does this minimal config work with kernel 5.12?
I will take a try, the only issue I have with mine config is that I don't have the battery status
Kind regards,
Xavier Miller.
Hi @xyzzy, your defconfig works very well on 5.12!
I have everything working now, thank you very much!
Kind regards,
Xavier Miller.
I am also working on regularly maintaining my own minimal PBP config, focusing on simplicity and performance, here[1]. I will be iterating on this and attempting to keep it up to date with the latest kernel releases. The first draft for kernel 5.19.3 works perfectly on my PBP running gentoo. Patches are welcome[2] and very much appreciated!
[1] https://git.sr.ht/~svmhdvn/dotfiles/tree...est.config
[2] ~svmhdvn/public-inbox@lists.sr.ht
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,541 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 8,794 01-22-2023, 09:55 PM
Last Post: rfm83
  Kernel panics on Youtube solostian 1 3,993 12-26-2021, 11:45 AM
Last Post: sirspate
  Screen refresh delay with kernel errors shawnanastasio 31 63,041 04-27-2021, 02:57 AM
Last Post: james64
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 14,593 10-28-2020, 01:16 AM
Last Post: 25519
  mhwd-kernel: command not found motezart 1 6,277 10-16-2020, 03:11 PM
  Boot custom kernel on PineBook Pro lowenware 7 15,195 07-06-2020, 03:31 PM
Last Post: lowenware
  Changed the bootsplash image - Kernel messages still showing Twix166 7 14,475 01-16-2020, 05:51 PM
Last Post: Arwen
  Debian: How to get kernel header files crusty 2 7,021 01-08-2020, 02:22 PM
Last Post: muma
