Another one boots to black screen
I got my pine book pro back in march, put towboot on the spi and ran armbian from the emmc. Happy! After a period of disuse including full battery discharge, it started booting to a black screen. Sad!
I put a new image of armbian on an SD card and it does the same thing. I opened the case and turned off the emmc switch and tried a fresh SD card. No change. I tried the long press hard reset. Same.
Tow boot is still working. When it boots to the black screen, the power light is green and the caps lock and num lock lights work.
I’m not sure what to do next.
Well, you could zero the SPI ROM, have the eMMC disabled, and boot to the SD card, assuming the SD card actually boots.
:wq
Towboot on the spi is the only thing that is working correctly. It does not boot to the SD card.
I think I’m going to replace the main board and emmc. Maybe a power surge from fully discharging the battery fried something.
I could not find another case like mine where the boatload works and nothing else does.
With a black screen I'm not sure how you could manage to zero SPI
Armbian AFAIK starts a ssh session, so if you can find the IP address.....
OR if that doesn't work (no wifi connect) plug a usb-ethernet dongle and ethernet in
I was able to get it to boot with a usb drive with the original version of armbian that was previously working. Version 24.2.1, current 6.6.16, gnome desktop.
I will attempt the Sd card with this image and also will attempt to install on the emmc again.
Works with the sd card too. Appears the most current version of armbian is broken compared to this version.
Back booting from emmc. Happy. My issue was caused by a bad image of armbian. Thank you to the very chatgtp type response telling me to try other versions.
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 2,465 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 11,843 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 8,340 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,761 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 5,727 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 6,629 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 10,374 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 28,179 08-24-2021, 04:25 PM
Last Post: bkenn
  Flickering black window when opening settings Edgars10 0 3,216 06-06-2021, 05:42 AM
Last Post: Edgars10
  Screen refresh delay with kernel errors shawnanastasio 31 63,753 04-27-2021, 02:57 AM
Last Post: james64
