PIneBook Pro - Boot from SD
I just bought a secondhand Pinebook Pro and excited to try out different OSes from the sd card boot. But I cannot get it to boot from MicroSD.
It boots from the eMMC fine and is running Debian Stretch.
I can log in to rock account and ran the updater. I also manually ran `sudo apt update` and `sudo apt upgrade`. Seems like I am running latest kernel:
$ uname -r 4.4.213
I downloaded the latest debain installer `git clone https://github.com/daniel-thompson/pineb...taller.git` and ran `./install-debian`. This successully installed Debian to a MicroSD card. Which mounts mmcblk0-RootFS and mmcbllk0-Boot if I plug in the sd card after booting from eMMC.
But when I leave the sd in the slot and reboot, it still just boots from the eMMC.
Anything else I should try?
But there are at least 5 distros based on debian, maybe uname -a or look in /etc
You haven't said if you have tried other distros on SD,,
so, at this point you don't know whether it is SD or uboot to blame
So, I would say first to try another SD with another distro on it, mrfixit for example
it WILL be using the uboot on emmc at this point, some uboots are troublesome
(03-27-2021, 11:51 PM)wdt Wrote: >and is running Debian Stretch
Thank you. The solution was buying a new SD card. The two older ones I tried both failed.
  Video Editing Is Possible On The PineBook Pro! ImmyChan 12 17,413 11-10-2026, 09:48 PM
Last Post: noahclark
  Updated Pinebook Pro? tantamount 2 2,667 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,453 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,982 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,660 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,140 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,107 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,333 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 2,188 11-08-2025, 09:22 AM
Last Post: rfm83
  Bonk to boot biketool 2 2,964 10-21-2025, 09:08 AM
