Sudden Pinebook Pro boot problems
My Pinebook Pro has suddenly developed boot problems.
I have Danielt's Debian installed on emmc and it was working fine until today.
Now when I press or hold the power button nothing happens.
If I insert a MicroSD card with a distro installed on it and press/hold the power button the following happens:
1. I get a red light
2. Next I get a green light and the PBP boots the image installed on the emmc rather than the image on the MicroSD card.
Any Ideas on how I can fix it so I can:
1.boot from emmc without the presence of a MicroSD card.
2. boot from SDcard when one is installed.
Hi ndp
I'm also using Daniels Debian-Installer.
I noticed that since a couple of days, the boot process takes around 30-40 seconds instead of the usual 10-20.
Have you been able to get any console output from your install?
(01-13-2021, 04:18 AM)Tharadash Wrote: Hi ndp
I at some point have seen my PBP also increase its boot time. Turned out the original MODULES=list in /etc/initramfs-tools/initramfs.conf got changed to MODULES=most, which is Debian's default. Probably the whole file got replaced during one of the updates, because I usually also set KEYMAP=y instead of its default KEYMAY=n and that was reset too. I run kernel 5.8.5 built with pbp-tools script, and with it I currently have set MODULES=dep. Works fine and boots pretty quickly.
P.S.: I also have MrFixit's v2.0 u-boot on eMMC and I've removed maxcpus=4 from /etc/default/u-boot together with the snippet in /etc/tmpfiles.d/ that re-enables big cores during boot.
This message was created with 100% recycled electrons
I had no joy fixing this boot problem, so I booted of a MicroSD running MrFixit's Debian Mate image and then re-installed to the eMMC using Danielt's Debian installer.
This time I installed the default "bullseye" version rather than the "buster" version that I specified on the previous install.
So far, the new bullseye install seems snappier and more stable.
  Video Editing Is Possible On The PineBook Pro! ImmyChan 12 17,394 Yesterday, 09:48 PM
Last Post: noahclark
  Updated Pinebook Pro? tantamount 2 2,656 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,444 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,978 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,656 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,134 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,101 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,330 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 2,182 11-08-2025, 09:22 AM
Last Post: rfm83
  Bonk to boot biketool 2 2,956 10-21-2025, 09:08 AM
