PSA: Transition in progress - don't update !
#21
I also broke my mobian with update to 5.9 and after that found this thread - too late. But today I managed to update it more or less cleanly (using only instructions from apt update) and without reflashing. The only issue now I have 2 kernels - 5.8 and 5.9 (active), so 5.8 will need to manually uninstall.
#22
I am using Mobian on an SD card to port Kalliope. I upgrade using apt-get and managed to bork my device about 2 hours before finding this thread. It all seemed to work however, there was no sound, incoming or outgoing. Yesterday I once again upgraded. Not realizing that it was a full-upgrade situation I had some issues but in the end it all worked.  "sudo apt-get full-upgrade"
5.9 kernel, sound works again, pretty good quality too, however, on incoming calls, the phone wakes up, rings, but does not allow me to answer! lol
No problems calling back, Smile
I have managed to load the dependencies (with one exception) for Kalliope and I have managed to build it. A 3 hour build, felso t like I was back in the 1990's lol, The one exception is the library libttspico-utils. This is related to the pico TTS application. The package exists in x86 Debian but I suspect I may have to build it for ARM. I  figure I should ask before I do that if anyone knows if this package is available for ARM.
Thanks to all who contribute
LF
#23
(11-05-2020, 06:24 PM)HLing Wrote:
(11-05-2020, 04:55 PM)a-wai Wrote:
(11-05-2020, 10:28 AM)bcnaz Wrote: Should we consider November 04  or  05  as a  'reference'   release  ?
Definitely not, things will probably take a few more days to stabilize, maybe even a whole week... Rest assured I'll let you all know when the next reference release is out
What to do when I get this?:
sh: 1: /usr/sbin/u-boot-install-pinephone: not found
u-boot-install-pinephone  is superseeded by u-boot-install-sunxi64
#24
(11-07-2020, 04:44 AM)devrtz Wrote: u-boot-install-pinephone  is superseeded by u-boot-install-sunxi64
Hmmm no, u-boot-pinephone still exists
#25
Oops, right. Don't know what I was thinking!
#26
[quote pid='82556' dateline='1604622255']
[/quote]
So no worries. I did a fresh install. followed with a u-boot-install-pinephone.  After the self-inflicted complication that came from not having a fully charged pinephone (when will I ever learn?!), and remembering to use Disk utility from a newer computer so that I could "grow the rootfs", (Jumpdrive 5.0 did not automatically increase the rootfs, I think maybe because the older computer's Disk utility?) I was able to boot successfully into the new 5.9 kernel. By this weekend's update I was happily noticing that the battery life seemed stabilized quite a bit more.  This morning, I confirmed that finally I was able to connect my pinephone to the laptop via USB, at which time the internet became available to the laptop. Hurray!  (I could have used wifi, but really preferred wired tethering)
So many good things in week one of the 5.9 kernel.  Thank you!
#27
i have seen this post to late -.- . I have forced the update via apt now nothing work anymore. Please paste an information then the next stable image with the breaking chnages is available.
https://gitlab.com/mobian1/issues/-/issues/174
#28
(11-10-2020, 09:59 AM)lipkowski.be Wrote: Hi,
The 20201104 nightly worked fine for me for the last days. I installed the 20201110 today and it seems really good.
The nightlies are here.
#29
But if I install a Mobian nightly today, keeping it updated with APT is the same as re-flashing it with a new version? Is it possible to migrate from Nightly to "stable" afterwards without a complete re-flash?
#30
thanks i wait for the next stable version. Nightly are to unsecure for me, i don't want to crash my mobilephone again after a few days. My destionation is to use mobian  as productive os. I think the best way is to create a stable repo tree to solve this problems in future.
  No touch KB after update(forky) biketool 4 2,988 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,552 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 21,128 12-04-2024, 07:01 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 5,008 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 5,197 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 17,565 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 14,643 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 16,445 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 5,745 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 14,866 09-05-2022, 12:10 AM
