Manjaro - No battery info after plugged in
Just got my Pinebook, basically haven't changed anything from the stock Manjaro that came with it besides updating.
When I plug it in, the battery indicator disappears from the system tray, and the values in the Energy Consumption Statistics menu stops being updated. Even after I unplug it from the charger, the data continues to not update, and I have no way to check battery level. Battery level is set to always show in Configure System Tray. Power settings respond as expected to plugging/unplugging (screen dims when unplugged, brightens when plugged back in).
After a reboot things return to normal.
it seems that the manjaro default os has some problems with plugins, see this thread:
https://forum.pine64.org/showthread.php?...ght=upower
OK, good to know it's at least a known issue and not something I can fix on my own, so I can stop trying to solve it. Thanks.
It was a new bug in latest kde plasma 5.19, Should have been fixed by now but it will take few days to arrive at stable branch.
Manjaro ARM Team.
I am running Manjaro 20.09 on a PBP I received on Monday. The battery says 0% and thinks it will never finish charging, though it keeps running when I unplug it.
I swapped from USB-C to the barrel connector and it looks like it is charging - but it clearly wasn't at 0% before. Anyone know if Manjaro or something in the circuitry are setup to report the battery lower, if for some reason the charging info is inaccurate with USB-C charging, or if something else is the issue?
it doesn't get happy
it doesn't get sad
it just runs programs
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,590 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,238 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,358 02-19-2025, 12:49 PM
Last Post: zkajdan
  Improved battery life with TLP daemon Surehand53 0 3,489 12-30-2024, 07:46 AM
Last Post: Surehand53
  Manjaro Sway Theme Broken Eighty8 1 4,104 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,650 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,002 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,249 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,488 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
