Manjaro Kde screen resolution
Does anybody know a way to change the resolution from the default 1920x1080 to something like 1366x768? The KDE display manager only has the 1920x1080 option in the scroll bar.
You don't want to change a built-in LCD panel's resolution. These LCD panels are generally not smart enough to actually scale properly. Several people have soft bricked their Pinebook Pros by doing so. (Soft bricked meaning after some effort, they got them fixed without replacing any hardware, except perhaps using a MicroSD card.)
So, what can you do instead?
  • Increase the font size
  • Use a font with more pronounce features
  • Increase the various window manager sizes, (like increase the height of the tool bar)
  • Change the color scheme to be easier on the eyes, (even though it may not be bigger, proper contrast can help usabilility)
  • Change the window manager's decorations.
  • Use a workspace manager, (so one application per workspace)
  • And, when at home or office, use an external monitor
Anyone else have suggestions?
Arwen Evenstar
Princess of Rivendale
just use fractional scaling.
(05-29-2020, 04:19 PM)Arwen Wrote: You don't want to change a built-in LCD panel's resolution. These LCD panels are generally not smart enough to actually scale properly. Several people have soft bricked their Pinebook Pros by doing so. (Soft bricked meaning after some effort, they got them fixed without replacing any hardware, except perhaps using a MicroSD card.)
Your suggestion to increase the font size is actually good. I was able to do so and also increase the size of some of the icons as well. Things are easier to see now. Thanks a lot!
Your welcome.
One thing I forgot, is that changing the X-Window's DPI, (Dot's Per Inch), can help too. Can't remember off hand which direction makes things bigger. I've decided that this subject comes up enough for a Wiki section. I've cross referenced the trouble shooting section with the new Improving Readability & Usability section;
Wiki - Pinebook Pro - Improving readability
Wiki - Pinebook Pro - After changing builtin LCD resolution, blank screen
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
  Another one boots to black screen Sb2024 7 7,177 11-06-2024, 11:27 PM
Last Post: Sb2024
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 2,333 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Manjaro versions bad and good gilwood 0 2,763 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,151 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 5,052 12-13-2023, 08:17 PM
Last Post: trillobite
  Black screen by start up bluedemon382 10 11,252 07-27-2023, 07:49 AM
Last Post: dstallmo
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 488,643 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 5,628 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 7,916 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,215 04-01-2023, 03:21 AM
Last Post: hacknix
